[Acer 6930G] Lower +5V problem.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: [Acer 6930G] Lower +5V problem.
    Originally posted by nomorebeer
    I was check PQ16 before and;
    FET named PQ16 for 5V_S5 out, it's using same +15V for gate. And output is stable. I mean PQ16 pin 123 is 5.07V not decreasing.
    So if the problem is 15V, also this PQ16 has to be any problems too?
    Well you can try to replace PQ16 but I won't guarantee that will solve the problem.
    Muh-soggy-knee
    • nomorebeer
      • May 2013
      • 35
      • TR
      No, no i guess you misunderstand, i talk about PQ16 because, this FET like PQ14. Both gates connected same 15V. But, PQ16's all voltages are ok but PQ14's not. So i meant if the problem is 15V which is you thiking about 15V cold be a problem as a 13.5V. So i just wondering if the 15V is the problem, so should both of get some voltage decraasing on them. But only PQ14 has problem...
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Ok, yes indeed I got a bit confused there, sorry!
        Could you check the resistance of PR94, PR95, and PR100?
        Muh-soggy-knee
        • nomorebeer
          • May 2013
          • 35
          • TR
          I checked 3 of them, all working fine. :\
          P.S: Maybe you want to know, i replaced PQ19 too . And i checked now all MAINON_ON_G line resistors, PR94, 95, 100 , 92, 96 , 98 etc.. all working fine. PQ19 working fine.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Checked the MAINON signal?
            I'm still thinking it is either a problem with the voltage tripler, or the power management IC itself.
            Muh-soggy-knee
            • nomorebeer
              • May 2013
              • 35
              • TR
              #26
              Yes MAINON is OK on stand by mode, 6V. When i run the computer, voltage goes 0V.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                I did a little thinking, PQ30 or PQ31 could be bad. Could you test them?
                Muh-soggy-knee
                • nomorebeer
                  • May 2013
                  • 35
                  • TR
                  #28
                  Thank you so much your suggestion but, is those 2 Fets for 5VPCU side right? I mean 5VPCU is always FINE. 5.07. do you thinking still those ones could be a problem?
                  • nomorebeer
                    • May 2013
                    • 35
                    • TR
                    #29
                    I still got nothing.. any ideas? :\
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #30
                      The way i see it, this has got nothing to do with the switching transistors. It shouldn't, either - a transistor only runs in 2 states in a switching power supply: fully ON (low resistance) or fully OFF (open). So if the transistors have gone bad, it won't work at all. Besides, the power supply has feedback, which should prevent this kind of thing from happening.
                      You should trace the affected 5v rail down to the feedback pin of the controller. Then solder a little wire wherever you have a pad available on that trace (as the controller will be QFN and impossible to probe), and probe there. If the feedback voltage also drops, and the controller does not take action (which it seems it does not), replace the controller chip.
                      A working TV? How boring!
                      • Francisco.s
                        • 686
                        • Spain
                        #31
                        Do you know if PQ14 gets abnormal temperature?
                        • nomorebeer
                          • May 2013
                          • 35
                          • TR
                          #32
                          Hello, thank you for your answer. I just look out ISL6237's datasheet, so there is an example to use this chip for standart 5V/3.3 usage. So looks same on mainboard datasheet. In this case it's using PHASE1 (LX1) pin16 for feedback you talk about (guess). So i checked there there is really unstable votlage there. I want to say, i removed every parts i can, like LCD, Graphic Card, Wireless module etc. There is Only CPU Fan Connected. So;
                          First, ISL6237'S out pin, pin10(OUT1) always stable 5.07V.
                          when the cpu fan is running: Pin16 is like running between 1.50V - 3.2V. Changing very fast, not stable.
                          when the cpu fan is stopped: Pin16 running between 0V. - 1V. Not stable, changing fast.
                          additional information, there is PC45 connected Pin16 to Pin17(BST1);
                          when the cpu fan is running: PC45's other leg is like running between 4.90V - 5.80V. Changing very fast, not stable.
                          when the cpu fan stopped: PC45's other leg is like running between 3.0V - 4.10V. Changing very fast, not stable.
                          What do you think? The problem is ISL6237's itself?
                          • nomorebeer
                            • May 2013
                            • 35
                            • TR
                            #33
                            No, there is no temperture problem.
                            • Francisco.s
                              • 686
                              • Spain
                              #34
                              If you have a stabilized 5 volts at drain terminal of PQ14, and is not stable at source terminal, probably the voltage at gate terminal also fluctuates. (could be there is some ripple)
                              Try to short-circuit drain and source of PQ14, to evaluate if voltage is stabilized at both terminals.
                              You can not check voltage at pin 16 of ISL6237, because it is the output of a PWM circuit, so there is a square wave that should be checked with an oscilloscope.
                              • nomorebeer
                                • May 2013
                                • 35
                                • TR
                                #35
                                Short-circued voltage is 5.07V.
                                Actually, i tried to check pin25 too, ( its other phase for 3.3V i guess. i check ISL's datasheet and mainboard's datasheet it's looks like that.) So, pin25 is PHASE2(LX2) is always stable , 11v. But phase1 (pin16) is not stable. Any idea?
                                • Francisco.s
                                  • 686
                                  • Spain
                                  #36
                                  Then, is the laptop working properly now? (as long as voltage is stable now, I mean)
                                  I think it's due to variations in the amount of current consumption of the load connected to the +5VPCU circuit.
                                  • nomorebeer
                                    • May 2013
                                    • 35
                                    • TR
                                    #37
                                    Guys, any ideas?... I still got nothing :\
                                    • Francisco.s
                                      • 686
                                      • Spain
                                      #38
                                      I know you can not let mosfet short-circuited forever, but I wonder if laptop runs properly that way. (with mosfet short-circuited)
                                      • nomorebeer
                                        • May 2013
                                        • 35
                                        • TR
                                        #39
                                        Thank you for your answer but, Laptop is working properly before starting voltage drops. So, when shotcuited, voltage will never drop so should work always i guess.
                                        • Th3_uN1Qu3
                                          Believe in
                                          • Jul 2010
                                          • 6031
                                          #40
                                          Sometimes it's better to address the effect than the cause. If the laptop works properly like that, leave it shorted. That MOSFET is just acting as a simple ON/OFF switch there.
                                          Edit: You say the computer resets when trying to check MAIND. That indicates a problem there, it means that whatever is driving the MAIND signal has a very high output impedance... To drive the gate of a FET you would need a relatively low impedance source. Instead of shorting the FET you could do a more elegant solution: Pull the gate up via a 1k resistor to 5V_ALW. That should do the trick, and also have the circuit that's controlling MAIND work properly. There's a good chance that it's still able to drive the signal LOW when the computer is turned off.
                                            09-06-2024, 05:27 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Aspire A317-53-369X + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A317-53-369X + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-369X + Pack Gold Acer 17'' boardview and A317-53-369X + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-07-2024, 03:10 AM
