Chicago_cp_hpc
  • dycc
    Vision
    • Nov 2011
    • 624
    • Côte d'Ivoire
    Chicago_cp_hpc
    hi
    I received a laptop with keyboard issue.
    but whatever one you insert, there are series of keys that do not work.
    I already flash the bios but it's always the same thing.
    After testing with the multimeter, I found that the output of +V3.3A had not correct impedance (34 ohms).
    I suspect EC. but to be sure , i need diagram (CHICAGO_CP_HPC 630 hp).
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: Chicago_cp_hpc
    did you try another, good keyboard ? If you did, change capacitors near keyboard scoket.
    • dycc
      Vision
      • Nov 2011
      • 624
      • Côte d'Ivoire
      Re: Chicago_cp_hpc
      YES try with 3 good keyboard
      • dycc
        Vision
        • Nov 2011
        • 624
        • Côte d'Ivoire
        Re: Chicago_cp_hpc
        will change capacitor
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          Re: Chicago_cp_hpc
          sometimes there are group caps, sometimes they are alone. But you will change lots of caps. Good luck.
          • dycc
            Vision
            • Nov 2011
            • 624
            • Côte d'Ivoire
            Re: Chicago_cp_hpc
            thank man . very hard and tedious work
            • orientalsniper
              • Apr 2013
              • 459
              Re: Chicago_cp_hpc
              Can you report back if you make it work?
              • dycc
                Vision
                • Nov 2011
                • 624
                • Côte d'Ivoire
                Re: Chicago_cp_hpc
                It was faulty ec
                • focus2k
                  A1502 EMC2835 can´t insert another Serial
                  by focus2k
                  Hello all,
                  i just tried to insert the Serial C02RK106FVH6 in the attached Bios.
                  I tried to insert and Clean the Region, but it does not work.
                  Could anyone insert the Serial into this BIOS? THX a lot....
                  08-27-2022, 02:59 PM
                • tracker1
                  Insert OA3 id in bios - Lenovo V15 G4
                  by tracker1
                  Hello. I want to insert OA3 id - product id and license key in bios for model Lenovo V15 G4 IRU. I followed the instructions for OA3 tool and managed to get an OA3.bin file with the license key to write the MSDM table. The next step is to write it with the flash utility matching the bios producer, but I didn't succeed.
                  I have attached 2 pictures with no license and with license how it supposed to look like, the dump and the oa3.bin file. I can't seem to find another laptop with windows preinstalled to copy from there.
                  Can anyone help, please?
                  Thank you...
                  03-28-2025, 07:14 AM
                • lord2321
                  BIOS insert for the MSI MS-16U6 laptop, board version MS-16U61 rev.1
                  by lord2321
                  Hello. I am looking for a bios insert for MSI MS-16U6. MS-16U61 rev.1 board.
                  I can't find the bios for this board anywhere. Please help.
                  12-06-2023, 06:32 AM
                • bajdik
                  Lenovo ThinkPad OCP and impedance of Intel i7-10750H
                  by bajdik
                  Hello, I would like to know if reading of 1.6 OHM on i7-10750H is too low or not.
                  I can not compare - no other board with 10th GEN for measurement.
                  Thank you very much for your help.
                  08-09-2024, 03:38 AM
                • clearchris
                  "Low Impedance" vs "Low ESR"
                  by clearchris
                  From my research, "low impedance" are pretty much the same as "low esr" caps except the "low esr" caps come in a smaller package. Am I reading this wrong? "Low impedance" caps seem to be much more commonly available (and cheaper) than "low esr" caps. I'm not afraid to lean over some caps if I have to make them fit because of size.
                  I'm about to pull the trigger on a pretty large cap order (for me) and want to make sure I'm not buying the wrong stuff. I'm stuck in the house, busy working through my electronics projects, and it would...
                  03-26-2020, 09:12 AM
