Samsung Np-R510 no charge.
  • pocgoc
    • Nov 2012
    • 36
    • Singapore
    I've got a this Samsung R510,
    I press the power button it comes on but maybe in a minute time it powers off (with the charger and battery plugged in).
    If i leave it by itself with the charger plugged in (to build up a charge) and come back in 15 minutes it powers up no problem ,no random power offs.
    It doesn't charge the battery always 40% as if i plug out the charger the laptop turns off and fails to use the battery as a power source.
    I'm trying to to use this diagram.
    I've trying to follow the Schematics of the R510 on the Power and charge Mangement page this board has an ISL6256ahrz IC controller not the ISL6256AHRZ-T like here
    http://www.scribd.com/doc/135554184/Schematic-Diagram
    Can i get help diagnosing which resistors and Gateways and Pins please.
    I've replaced the DC Port
    I've replaced the Charger
    I've replaced the Battery.
    And i think i might have to replace ISL6256AHrz
  • pocgoc
    • Nov 2012
    • 36
    • Singapore
    Re: Samsung Np-R510 no charge.
    Mesaured the voltage of each pin:
    • Tuomo
      • 163
      • Finland
      Check chips Q5, U3, U4, D7.
      Then you can measure voltages on those chips.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        EN = 00.2, vdd=0.8 find out why ? it looks like your problem is EC, not giving enable command to charger ic. Dcin is 18.89 is ok. But vdd is also not ok. vref =2.4 ok. btw did you measure this values with battery or without ?
        • Tuomo
          • 163
          • Finland
          What do you think ACPRN and DCPRN?
          When AC Adapter is inserted ACSET, DCSET are > 1.26V so ACPRN and DCPRN should be LOW.
          • pocgoc
            • Nov 2012
            • 36
            • Singapore
            With battery in the values were measured.
            • pocgoc
              • Nov 2012
              • 36
              • Singapore
              without battery just charger
              Q5 :
              d= 19.03 g=9.50
              d= 19.03 s=19.04
              d= 19.03 s=19.04
              d= 19.03 s=19.04
              U3 :
              d= 19.03 g=18.03
              d= 19.03 s=18.53
              d= 19.03 s=18.53
              d= 19.03 s=18.53
              U4 :
              d= 0.438 g=18.52
              d= 0.438 s=18.54
              d= 0.438 s=18.53
              d= 0.438 s=18.53
              D7 has no chip soldered on to it its missing.
              • pocgoc
                • Nov 2012
                • 36
                • Singapore
                with charger and battery plugged in.
                Q5 :
                d= 18.89 g=9.41
                d= 18.89 s=18.92
                d= 18.89 s=18.92
                d= 18.89 s=18.92
                U3 :
                d= 18.89 g=17.72
                d= 18.89 s=18.25
                d= 18.89 s=18.25
                d= 18.89 s=18.25
                U4 :
                d= 11.30 g=18.24
                d= 11.30 s=18.23
                d= 11.30 s=18.23
                d= 11.30 s=18.23
                • Tuomo
                  • 163
                  • Finland
                  Q5 :
                  d= 18.89 g=9.41
                  d= 18.89 s=18.92
                  d= 18.89 s=18.92
                  d= 18.89 s=18.92
                  U3 :
                  d= 18.89 g=17.72
                  d= 18.89 s=18.25
                  d= 18.89 s=18.25
                  d= 18.89 s=18.25
                  U4 :
                  d= 11.30 g=18.24
                  d= 11.30 s=18.23
                  d= 11.30 s=18.23
                  d= 11.30 s=18.23
                  U3 Gate voltage is 17V, it should not be OPEN if it same type as Q5.
                  Can you measure U3 chip.
                  Is there D522 chip?
                  Can you measure just Battery ON.
                  When AC Adapter is inserted ACPRN and DCPRN should go LOW.
                  This means at AC Adapter not detected, that is reason why not charging.
                  U3 control is also ACPRN so that is reason why Gate 17V.
                  I think ISL6256AHrz is failed.
                  • pocgoc
                    • Nov 2012
                    • 36
                    • Singapore
                    Is there D522 chip?
                    Thanks mate , I've ordered a ISL6256 IC .
                    There is no D522 chip either.
                    • Francisco.s
                      • 686
                      • Spain
                      Could anyone post a link to the Samsung Np-R510 in pdf format?
                      Thanks.
                      • pocgoc
                        • Nov 2012
                        • 36
                        • Singapore
                        Thanks.
                        • Tuomo
                          • 163
                          • Finland
                          No problem, check U3 too it may broken also.
                          Use resistance mode and measure D to S and S to D.
                          It should show high resistance other side and low resistance other way.
                          • pocgoc
                            • Nov 2012
                            • 36
                            • Singapore
                            Thanks .
                            D->S =OL (very high)
                            S->D =2.716
                            S->D =2.716
                            S->D =2.716
                            Again Thanks
                            • Francisco.s
                              • 686
                              • Spain
                              Hi pocgoc, ACSET, (pin 27) detects the presence of AC Adapter, so you should check the value of R532, R573, and R794. They sets the voltage to detect the AC adapter. (should be > 1.26 volts, when AC Adapter is present)
                              Regards.
                              • pocgoc
                                • Nov 2012
                                • 36
                                • Singapore
                                Regards.
                                couldn't find R573 on schematic page.
                                But r532 was constantly rising in Mega ohms (damaged).
                                R533 = 26.5K
                                R794 = 300K
                                • Francisco.s
                                  • 686
                                  • Spain
                                  R533 = 26.5K
                                  R794 = 300K
                                  I think you have encountered the component that causes the problem.
                                  If value of R532 is not what schematic says, (300K) then the voltage at pin 27 will be wrong, and AC adaptor won´t be detected.
                                  You should replace it. I have mistaken R573, I wanted to say R533.
                                  Regards.
                                  • pocgoc
                                    • Nov 2012
                                    • 36
                                    • Singapore
                                    Regards.
                                    Thank you Fanncisco.s for extremely helpful knowledge and time.
                                    • Francisco.s
                                      • 686
                                      • Spain
                                      Some pint of Guinness!!
                                        09-07-2024, 05:50 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
                                        Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 06:20 PM
