Acer 7736zg No power
  • bollin
    • Mar 2013
    • 104
    • Finland
    I got an acer aspire 7736zg that is showing no signs of life. No Leds come on, only a ticking sound (one tick per second). I measured voltages, and found that there are 19.8 volts on the MOSFETs close to the dc jack, and also to the IC near the battery connector. There are two MOSFETs (FDS8884) near the battery IC, one had 19.8 volts on drain, gate & source were about 1.8 volts and dropping slowly. I checked the MOSFET and it showed a short between gate and source, so i replaced it, but still the same (but 0 volts on gate this time).
    I found 3.3 volts on the power switch, and it went to zero when pressed. The ticking also seemed to disappear, but i didn“t it only ticks once every ten seconds when power switch is pressed.
    The mobo is a Hannstar j mv-494-0 (all the numbers i could see)
    p/n is 55.4FX01.581G
    Does anyone have a schematic for this?
  • dj_ricoh
    • 2073
    • uk
    Re: Acer 7736zg No power
    after you remove the mosfet did the short was on the mb to? check that !
    • bollin
      • Mar 2013
      • 104
      • Finland
      The short was gone after replacement, so i guess thewhatever the problem is it caused the mosfet to short (but this is just my guess)
      • mytomr
        • Feb 2012
        • Philippines
        What is the function of defective MosFET on the circuit.(series pass or switching for DC-DC), if in series pass config does gate voltage present (usually it came from logic controller e.g. syscon normally hi for on and lo for off), but if use in DC-DC circuit as switching then check the oscillator IC it might be te culprit.. consult datasheet of the ic it may help you..
        • bollin
          • Mar 2013
          • 104
          • Finland
          I must say, I don“t know. The FDS8884 is labeled U32 in the schematic (SI4800BDY-T1). To me it looks like it is used in series pass?
          • bollin
            • Mar 2013
            • 104
            • Finland
            It seems as the 5v s5 is missing, so i will replace ISL62392hrtz.
            • bollin
              • Mar 2013
              • 104
              • Finland
              The board is a jv71-mv with ddr3 memory.
              • Francisco.s
                • 686
                • Spain
                U32, U33 and L10 are part of a circuit called Buck converter. (circuit switching for DC-DC)
                http://en.wikipedia.org/wiki/Buck_converter
                Regards.
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  can you tell the current on standby (s5) ?
                  • bollin
                    • Mar 2013
                    • 104
                    • Finland
                    No, as i currently does not have the possibility to do so. A lab power supply with current limiter is under construction, though.
                    However, I was looking at the schematic, and i have some questions.
                    The power, standby and charging leds are all powered by the 5v_s5, and are controlled by the kbc through switching transistors. So, there should always be 5 volts present, when the power supply is connected, right? If there isn“t 5 volts, i should look at the 5v_s5 rail, otherwise it is the kbc that is the reason for the leds not turning on?
                    I am not saying that the problem is there, I am just asking to see if I understood it correctly.
                    I know for a fact that the 3v/5v VRM is bad (my mistake) and I have ordered a replacement, and I can“t do very much testing until I have got it replaced.
                    • spidey
                      climbs
                      • Dec 2012
                      • 644
                      • Cyprus
                      When the power supply is connected, you should have 5v and 3.3v. That is the first stage of power in laptops. right now i dont have the schematics for this mobo. But 2-3 hours later when i arrive home, i'll search it for you. But it is a bit difficult to solve the problems without current monitoring. if you will work on laptops, it is a must.
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        Also check rtc(must be at least 2.6v) and re-program the bios if you have 5v and 3.3v. if all didnt work, then you may replace kbc.
                        • bollin
                          • Mar 2013
                          • 104
                          • Finland
                          Regards.
                          Then the 1.8 volt that I got is good, if I understand things correctly.
                          Thanks for all the help, I“m learning loads here, even if it doesn“t help in this particular case.
                          • Francisco.s
                            • 686
                            • Spain
                            What chip the 1.8 volts are related to?
                            I have a schematic, but don“t know if it is the same as yours.
                            • spidey
                              climbs
                              • Dec 2012
                              • 644
                              • Cyprus
                              Video chip, DDR2 memory, chipset north.
                              • Francisco.s
                                • 686
                                • Spain
                                Then I think we have the same schematic, and as I can see mosfet U23 and U25 are controlled by U22, and thorough L26 we have the 1D8V_PWR, so I can“t understand the relationship with the ISL62392 and this circuit. ¿?
                                I'm lost somewhere.
                                • spidey
                                  climbs
                                  • Dec 2012
                                  • 644
                                  • Cyprus
                                  can you upload the schematic?
                                  • Francisco.s
                                    • 686
                                    • Spain
                                    This is the schematic I have.
                                    • spidey
                                      climbs
                                      • Dec 2012
                                      • 644
                                      • Cyprus
                                      i'm a bit confused. if you have 1.8v u should have 5v and 3.3v also. And after you press the power button you can get 1.8v and the other secondary voltages. So did you measure L27 and L28 ? And can you tell me, you have 1.8v after pressing power button or before ?
                                      • Francisco.s
                                        • 686
                                        • Spain
                                        I'm also very confused, as @spidey says, something doesn't match.
