Acer 7736zg No power
  • bollin
    • Mar 2013
    • 104
    • Finland
    Re: Acer 7736zg No power
    Ok, let me clarify things. Firstly, I got the 1.8 volt reading before I replaced anything. Then I replaced the fds8884 and still got 1.8 volts.
    Secondly, I started to suspect the ISL62392 and when I was reading voltage in I slipped with my probe and it got fried. My mistake, as I mentioned earlier.
    So, now I have to wait for my replacement isl62392 to continue troubleshooting.
    Hope you are a little less confused now.
    • bollin
      • Mar 2013
      • 104
      • Finland
      Originally posted by spidey
      can you tell me, you have 1.8v after pressing power button or before ?
      Nothing happened when inserting the power supply or pressing the power button. All voltages that i have measured are with power supply plugged in. At first I had 3 volts on the power button, but since I accidentally fried the isl62392 I haven´t got that.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        You can not get 1.8v if there is no 5v and 3.3v.
        • bollin
          • Mar 2013
          • 104
          • Finland
          No, and I don´t as it is now. I did get it when the isl62392 was still working.
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            ok, after you solder it we continue
            • bollin
              • Mar 2013
              • 104
              • Finland
              #26
              Ok, so I got the replacement today, and soldered it in. When I plug it in, the power supply goes crazy and the isl62392 gets very hot. I don´t quite know what went wrong. I was a little bit sloppy with ESD, so that might have broken it. Now I have to order another replacement...
              • bollin
                • Mar 2013
                • 104
                • Finland
                #27
                Today I got the replacement, and as I had the "broken" one desoldered I decided to do some testing. First I checked if the short on dcbatout was still there, and to my surprise it still was! So I started checking caps between dcbatout and ground, and so far I have found none that is bad. There are quite a few to check, so I decided to leave that for the moment and check the 5v and 3v rail for shorts. Turns out that the 5v line was shorted, so I desoldered the coil, and found the short to be at u58. After I removed it it seemed like the short on dcbatout was gone too. I found a replacement from another board, and soldered it in, still no short. Soldered in the new isl62932 and checked again, still looks good. I let it cool, and plugged in the charger, and again it goes in to short circuit protection. And the short is back. I´m running out of ideas here...
                • bollin
                  • Mar 2013
                  • 104
                  • Finland
                  #28
                  I removed U64, and now dcbatout is at 18.64 volts, AD+ is at 19.22 volts. No 3d3v_s5, 3d3v_aux_s5, 5v_s5 or 5v_aux_s5. I have ordered new fets for the 5v and 3v rails. There is probably one or more defective fets on those rails, and perhaps that is why it won´t work and that the dcbatout is at 18.64 volts instead of 19.22 that it should be.
                  • Tuomo
                    • 163
                    • Finland
                    #29
                    Can measure U62 pins?
                    • bollin
                      • Mar 2013
                      • 104
                      • Finland
                      #30
                      I can measure the U62 pins, but since there are no voltages present at all (except dcbatout) it is probably bad. Before I measure pins I will check for shorts on 3d3v_aux_s5 and 5v_aux_s5. If there aren´t any shorts, I will replace it and measure pins then.
                      • bollin
                        • Mar 2013
                        • 104
                        • Finland
                        #31
                        Ok, I have found some time to work on this thing again, and made some progress. Turns out that the 3d3v_aux_s5 was shorted, and I believe that the KBC is the cause of that. I removed it and the resistance is now at a more "normal" level. So, I will order a replacement for it.
                        The 5v_s5 is still not good, and I don´t know where to look for problems since I haven´t got the right schematic for it (I desoldered the coil and found that the problem is probably on some IC powered by the 5v_s5 rail). I only got the DDR2 version where the power sections is the same when it comes to the 3v/5v rails, but on the others it (of course) different. Anyone got the JV71 DDR3 schematic?
                        • bollin
                          • Mar 2013
                          • 104
                          • Finland
                          #32
                          I found dthe schematic, back to work.
                          • Francisco.s
                            • 686
                            • Spain
                            #33
                            Can you upload the new schematic?
                            • bollin
                              • Mar 2013
                              • 104
                              • Finland
                              #34
                              Yes, here it is
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                #35
                                [EDIT: My bad... )
                                Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                • Francisco.s
                                  • 686
                                  • Spain
                                  #36
                                  Time for a reflow?
                                  First try to reprogram bios chip. (U19) (MX25L1605D)
                                  Could be it has some corrupt data.
                                  Good luck.
                                  • Francisco.s
                                    • 686
                                    • Spain
                                    #37
                                    Originally posted by Khron666
                                    [EDIT: My bad... )
                                    • stealth
                                      • Oct 2013
                                      #38
                                      hi guys just wondering if you got this working or not ? I have the same JV71-MV motherboard with same problem with ticking sound and no LEDs at all.
                                      • bollin
                                        • Mar 2013
                                        • 104
                                        • Finland
                                        #39
                                        I haven´t got it working yet. It has been on the shelf now for a while, but last week I decided to attend to it again. So I have ordered some parts and now I am fairly confident that I will get it working again.
                                        My advice is to check U58, U59, U63 and U64.
                                        • bollin
                                          • Mar 2013
                                          • 104
                                          • Finland
                                          #40
                                          Now I have finally found the time to start this project up again. Today I started checking it again with my dmm, and found that 1d5v_s3 is shorted to ground. 3d3v and 5v also looked suspicious, but that is something I will look at later.
                                          I removed coil L58, and found that the short is after the coil, so I kept on removing IC:s that could be at fault, but the short didn´t go away. I removed U54, U69 and U74 but the short was still there on the 1d5v rail.
                                          Anyone got ideas where to look next? Checking caps?
