Sager 8887 with leaking caps
  • bob6987
    • Oct 2006
    I have a Sager 8887 with leaking caps, system still works. I am hoping to get them replace by badcaps.net. It was a good thing I clean out the hsf often before anything fried.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Sager 8887 with leaking caps
    deja vu
    https://www.badcaps.net/forum/showthread.php?t=2715
      by momaka
      03-12-2025, 03:42 PM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Blag
      Japanese 3DO with leaking caps - (nearly) full poly replacement
      by Blag
      Hi all, I've got a 1994 Japanese Panasonic 3DO with 2 leaking caps. Since all the caps are now 25 years old I decided to swap them all before more of them start to leak.
      To reduce the danger of another leakage in the future I decided to swap every possible cap with a poly cap.
      Has anyone here done that already and give me some hints?
      I found a "fitting" (voltage, uF and measurements) poly cap for all but 3 caps. The largest cap is a 6800 uF 25v cap, since there aren't any 6800er polys I'll get a high quality electrolyte one with a higher temp rating. The...
      10-26-2019, 07:59 PM
    • madscientist750
      Replacing electrolytic caps by solid caps on old motherboards
      by madscientist750
      I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
      I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
      I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
      10-19-2025, 06:10 AM
