toshiba u400
  • pctek
    • Apr 2012
    • 53
    • Greece
    toshiba u400
    I have a toshiba u400 that turns on for 1 sec and immediately off . When you connect the power adapter, battery seem to charge (charge light is on) . I took apart everything and found that if I remove the processor laptop power stays on . Tried different processor , problem the same . It doesn't have any nec/tokin caps on cpu socket . Any ideas ?
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: toshiba u400
    check cpu vcore power area...
    • Tuomo
      • 163
      • Finland
      Re: toshiba u400
      Remove CPU and measure resistance to CPU coils if resistance is low there is short circuit on motherboard.
      • pctek
        • Apr 2012
        • 53
        • Greece
        Re: toshiba u400
        Found 2 shorted capacitors . Removed both but when tested out of board seemed ok .
        • Francisco.s
          • 686
          • Spain
          Re: toshiba u400
          Have you got the schematic for this Toshiba?
          If you have an external power supply, (regulated and short-circuit capable) you can inject a low voltage to the positive connection of capacitors, (negative to ground) and see if there is something that gets hot. (another cap.)
          The voltage should be as low as possible, and increment in small-steps, if required.
          Good luck.
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            Re: toshiba u400
            Good luck.
            Also limit current to 200ma and increase slowly .
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              Re: toshiba u400
              What kind of power supply can be used for this and exactly how low should the voltage be?
                09-06-2024, 05:27 AM
                09-06-2024, 05:59 AM
                Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                09-06-2024, 05:33 AM
