Toshiba NB200. Hang up after Post?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Hello To all
    I Have Repair Toshiba NB200. Problem Is Hang-Up But can Go To Bios Setup if you Press F2. in a bios can change also Detect a Hardrive. Also Save Information.
    I CHeck The Following
    1, try Change Memory card and Install a 100% Ram not Luck
    2, Try Change a Sata Harddrive not Luck Again.
    3, I Clean all and Return the Original Parts. Not Luck
    4, I try To Reflow the South Bridge and Gpu. Not Luck Same Problem
    5 I Reflow the CPU. Same Us No Lock
    Other Solution There?
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: Toshiba NB200. Hang up after Post?
    what's ur boot order ?
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Sir Automatically Boot Up. i Wondered why after save then In Bios. the cdrom internal Stop Hdd Light Indicator notlight. i Used also USB cdrom nothing. only disply blak screen?
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        it is a known problem of this machine. Just desolder your bios spi eeprom and replace with new one programmed with the proper bios file from official web site. Usually the old one wont work, so find a new ic.
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          More Thank You My Friend. But I dont Know Where the SPI Eeprom location. Do you Have a Screen Shot, picture or Diagram ex. u12 or u13 ?????. you can point out which parts and which location? pls teach me Master?
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            its easy to find, look for a 8pin sop ic with a mark on it. a dot mark on the ic. and sst25x or w25x80 or 24cxx etc. i'll check it from the schematic and will write its marking.
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              U36 from the service guide. i need to know the main board model name to check from the schematic.
              • sasser
                • Dec 2012
                • 365
                • Malaysia
                Hang at startup is nm10 chip problem. If bios problem u cant see the bios information all blank screen
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  You are wrong, i've allready fixed at least 10 nb200 just re-programming the bios. And also this problem is a common problem of nb200's.
                  • sasser
                    • Dec 2012
                    • 365
                    • Malaysia
                    ok spidey just suggest to lorins_core if he has epprom programmer. reprogram the bios.let see if cant solve just change the nm10.
                    • lorins_core
                      BlackSmith
                      • Dec 2012
                      • 552
                      • Philippines
                      Master You Have a link of Schematic Diagram. Would you give the dl link. Thanks
                      • lorins_core
                        BlackSmith
                        • Dec 2012
                        • 552
                        • Philippines
                        Thanks Master I Try... i Post if Lucky done... i try to find bios file.
                        • Francisco.s
                          • 686
                          • Spain
                          You are right spidey, U36 is the bios chip, at least if schematic is a LA-5121P REV: 1.0
                          Regards.
                          • charafmak77
                            • Oct 2017
                            • 81
                            • jijel
                            thanks
                              09-06-2024, 05:27 AM
                              09-06-2024, 05:59 AM
                              09-06-2024, 05:33 AM
