Toshiba L650 power problem
  • Lykos
    • Oct 2012
    • 24
    • Greece
    Greeting to everyone!
    I have a Toshiba L650 that works perfectly good on battery, but does neither charge nor work on external power. I have attached the schematic of the power supply part of the board, so I cut to the chase.
    After some experiments I probably destroyed the charging chip (MAX17435ETG+) but it still works the same (even with the IC removed).
    I get 19v to the Drain of Q6002 (with adapter on but battery removed) but only 3v on the Source and nothing to the gate (same as before destroying the IC).
    With battery on, I get 12v on the source (probably because it's connected with Q6005 Source) and I have already replaced it althought it measured normal (just multimeter).
    The question might sound stupid after all this intro...
    I want to make the laptop work on the adapter. If I remove U6000 (the destroyed MAX17435ETG+), Q6002 and Q6005 and then short Q6002's source and drain, will it work without frying anything?
    Thanks in advance!
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Toshiba L650 power problem
    Lykos,
    see this thread
    https://www.badcaps.net/forum/showthread.php?t=8991
    replace the destroyed chip and proceed with the threads solution
    regards
    • Lykos
      • Oct 2012
      • 24
      • Greece
      I have read this post, in fact, I have replaced a couple of proadlizers with capacitors successfuly, but it is irrelevant with my question.
      • lord
        • May 2011
        • 319
        • Croatia
        Thanks in advance!
        I never tryed it, but it should work. However do it at your own responsibility!
        • Lykos
          • Oct 2012
          • 24
          • Greece
          At the end it didn't work. I'm still trying to figure out a way to make this thing usable again.
          Thanks for your answers!
          • lord
            • May 2011
            • 319
            • Croatia
            Did you try to replace the U6000? Did you test MOSFETs Q6000, Q6001, Q6002 and Q6005? Test D6000 and try to bridge D6005.
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              it will work fine . but don't use adapter and battery at the same time
              • laurentd
                • Nov 2012
                • france
                My Toshiba L655 has been the same problem (not battery charging).
                After replacement of the U6000 (MAX17435) the problem is fixed
                I found the fault by measurement of the ref value of the U6000.
                The output was at 0V !
                And without the battery and the ac adapter plugin the U6000 was very hot !
                For me the DCIN input that produce DC internal voltage and ref value was damaged.
                Thanks for your feedback
                Regards
                Laurent
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  hi, i have the sam problem. (i have only orangle blinking LED for battery low) no power when plug in adapter, i order U6000 (MAX17435) hope it will solve the problem. How did you test the U6000?
                  ...the quieter you become the more you are able to hear...
                  • Tuomo
                    • 163
                    • Finland
                    Plug AC adaptor ON.
                    Check U6000 PIN 10 ACOK = 0V this detect if AC adapter is ON.
                    Check L6000 = 12V. Charging voltage.
                    If those works U6000 probably works too.
                    If you use Battery +VBAT is 12V cause Battery has 12V.
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      hi, i measure the value of U6000 ACOK = 5.34V, and L6000 = 3.44V
                      • Kriseh
                        • May 2013
                        • 6
                        • The Netherlands
                        I measure this value's too on a L650 Thosiba which won't charge battery anymore (works with new battery from ebay) and doenst work with AC adapter only.
                        Can I now conclude the U6000 chip is damaged?
                        • Tuomo
                          • 163
                          • Finland
                          No, just AC Adapter not detected.
                          Measure PIN 19 ACIN this is pin which detect AC Adapter.
                          • Kriseh
                            • May 2013
                            • 6
                            • The Netherlands
                            Symptoms:
                            Thosiba runs fine on full battery, but can't recharge battery. Also with only AC Adapter plugged in I can't boot the laptop.
                            Measurements:
                            U6000:
                            ACOK (PIN 10) = 5.34V,
                            ACIN (PIN 19) = 1.69V
                            L6000 = 3.44V
                            • Tuomo
                              • 163
                              • Finland
                              Symptoms:
                              Measurements:
                              U6000:
                              L6000 = 3.44V
                              ACIN PIN19 1.69V indicate at there is AC Adapter inserted.
                              If ACIN PIN19 > 1.485V then ACOK = 0V.
                              ACOK PIN10 5.34V means at AC Adapter NOT detected.
                              If other voltages are OK, then U6000 may be FAILED.
                              • Kriseh
                                • May 2013
                                • 6
                                • The Netherlands
                                This are my readings with AC adapter ONLY:
                                PIN 1 = 0V
                                PIN 2 = 0V
                                PIN 3 = 19.25V
                                PIN 4 = 5.43V
                                PIN 5 = 0.1V
                                PIN 6 = 0.35V
                                PIN 7 = 5.43V
                                PIN 8 = 1.23V
                                PIN 9 = 1.36V
                                PIN 10 = 5.36V
                                PIN 11 = 1.23V
                                PIN 12 = 1.23V
                                PIN 13 = 1.23V
                                PIN 14 = 0V
                                PIN 15 = 1.51V
                                PIN 16 = 1.51V
                                PIN 17 = 0V
                                PIN 18 = 0V
                                PIN 19 = 1.69V
                                PIN 20 = 5.37V
                                PIN 21 = 4.10V
                                PIN 22 = 5.37V
                                PIN 23 = 0V
                                PIN 24 = 0V
                                Can you make any conclussions to replace U6000 or not?
                                • Tuomo
                                  • 163
                                  • Finland
                                  PIN 1 = 0V
                                  PIN 2 = 0V
                                  PIN 3 = 19.25V
                                  PIN 4 = 5.43V
                                  PIN 5 = 0.1V
                                  PIN 6 = 0.35V
                                  PIN 7 = 5.43V
                                  PIN 8 = 1.23V
                                  PIN 9 = 1.36V
                                  PIN 10 = 5.36V
                                  PIN 11 = 1.23V
                                  PIN 12 = 1.23V
                                  PIN 13 = 1.23V
                                  PIN 14 = 0V
                                  PIN 15 = 1.51V
                                  PIN 16 = 1.51V
                                  PIN 17 = 0V
                                  PIN 18 = 0V
                                  PIN 19 = 1.69V
                                  PIN 20 = 5.37V
                                  PIN 21 = 4.10V
                                  PIN 22 = 5.37V
                                  PIN 23 = 0V
                                  PIN 24 = 0V
                                  I would changed U6000.
                                  Thanks excelent measurement.
                                  • Kriseh
                                    • May 2013
                                    • 6
                                    • The Netherlands
                                    Thanks for sharing your expertise,
                                    I want to buy this one as a replacement:
                                    Ebay Link
                                    Is this one good to go? The number on the chip is slightly different from the one thats on the L650.
                                    Ebay: 17435ETG239ITBS+
                                    Motherboard: 17435ETG023ITAO+
                                    What is the easiest way to replace with low cost/home made equipment? I don't have any professional SMD tools
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      I replace one of these, you need IR soldering machine or you could try with hot air gun, but set ti to slow air flow
                                      • Dark_Angel
                                        • Oct 2012
                                        • 10
                                        • Portugal
                                        Hi to all i to have a client Toshiba l650 that have the same problem, it work´s from battery if it is charged but wont charge or run from ac adapter only.
                                        Im not an electronics engineer but i suspect the u6000 (maxim 17425e) its not ok.
                                        This are the voltages i get:
                                        PIN 1 = 0V
                                        PIN 2 = 0V
                                        PIN 3 = 19V
                                        PIN 4 = 5.43V
                                        PIN 5 = 0V
                                        PIN 6 = 1.7V
                                        PIN 7 = 8.7V
                                        PIN 8 = 3.6V
                                        PIN 9 = 3.7V
                                        PIN 10 = 5.4V
                                        PIN 11 = 3.6V
                                        PIN 12 = 3.6V
                                        PIN 13 = 3.6V
                                        PIN 14 = 0V
                                        PIN 15 = 3.6V
                                        PIN 16 = 3.6V
                                        PIN 17 = 0V
                                        PIN 18 = 0V
                                        PIN 19 = 1.7V
                                        PIN 20 = 5.4V
                                        PIN 21 = 4V
                                        PIN 22 = 5.4V
                                        PIN 23 = 0V
                                        PIN 24 = 0V
                                        Can someone confirm if they are correct? (i suspect not)
                                        Thanks in advance.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
