Dell Inspiron N5110 help!!
  • heavymachines
    • Mar 2011
    • 1028
    Re: Dell Inspiron N5110 help!!
    Originally posted by bushido
    hi heavymachines sorry for late replay i check the ac adapter port in the middel pin i cannot get any voltage output i try to check other ac adapter but the same still no volts output what do you think i need to check the dc jack port to? thanks for your help !!!!
    if no volts on center pin then replace the charger it will never charge the battery.....it will run the laptop but not charge it...if you want to double check it you can use anybody's dell charger does not matter just to test it however hp chargers out there will fit but its wired different will not work properly with a dell...
    • bushido
      • Oct 2012
      • 32
      • japan
      hi thanks i just want to ask i try to plug the ac only without the battery the pc will not power up what is the problem the dc jack or some component? sorry if i disturbing thanks by the way
      • heavymachines
        • Mar 2011
        • 1028
        some laptops will not run without battery present, some will, it depends on how they wired it inside on the pcb"motherboard" you will need to test the laptop with a known good charger for example if you have a friend that has a dell and it charges his battery then use that one to test yours and if battery charges then you have confirmed 2 times that you need a new charger... that center pin needs to put out 3 to 5 volts...
        • bushido
          • Oct 2012
          • 32
          • japan
          ok thank you very much i will find ac adapter to test it thanks
          • bushido
            • Oct 2012
            • 32
            • japan
            hi heavymachines this is now the situation i change the dc jack port on the mobo and i borrow a dell laptop with the same model of my friend i try to charge his battery on my ac adapter its ok i try to power up his laptop with the battery attach and without the battery only ac adapter its works fine and then i try again to my laptop i power up the laptop without the battery its not power on but i try again with battery attach its powerup without problem but its not charging and ddnt detect the ac on laptop and i check it on bios and no ac attach what its the problem plz help thanks sorry for very late replay
            • bushido
              • Oct 2012
              • 32
              • japan
              #26
              pls help this is the schimatic ssid charger for dell n5110
              the problem is it cant detect the ac and it cant use the ac as power source i check the ac port its ok i check the dc jack port its ok too i think its on mobo component that not function but i dont no where to find and what should i need to check plz help some veteran member thanks
              • heavymachines
                • Mar 2011
                • 1028
                take clear pictures of the motherboard both front and back and more around dc jack area and battery connector pins want to see what all between dc jack and battery connector area...so like 4 or 5 pictures so we can match up the schematics to the board and get a better understanding of function...and i want to see your solder job as well...
                • bushido
                  • Oct 2012
                  • 32
                  • japan
                  #28
                  ok thanks heavymachine i will take a picture after my work again thank you very much!!
                  • bushido
                    • Oct 2012
                    • 32
                    • japan
                    #29
                    hi i hope you can help me again thanks a lot
                    • heavymachines
                      • Mar 2011
                      • 1028
                      hate to say this, but i need a picture to see your solder work bottom view of dc jack..in meantime i will do some studying on workings of the charge system and try to match schematics with the pictures so we can get an idea where to test next..
                      • bushido
                        • Oct 2012
                        • 32
                        • japan
                        #31
                        this is the other picture i hope you can help me again thanks by the way heavymachine
                        • bushido
                          • Oct 2012
                          • 32
                          • japan
                          #32
                          hi heavymachine there's any update sorry if i disturb u i hope for any development thanks by the way
                          • bushido
                            • Oct 2012
                            • 32
                            • japan
                            #33
                            if there's any one here who can help me to fix this board i really appreciate thanks plz help
                            • heavymachines
                              • Mar 2011
                              • 1028
                              well considering a reflow made it work at all tends to lead to that ,however you can check all your power mosfets for shorts if all checks out then its most likely a connection issue somewhere either by the pcb sockets or dc jack something is not connecting, when power plug is connected to dc jack check all battery pins see which ones are getting voltage and which ones are not then the ones that are not fallow that to most likely a power fet or charge control ic you will need to do alot of testing to narrow it down....i have a feeling when you did the reflow that brought it back to life i am half considering something did not relow all the way check all connections....this will take time to do...
                              • heavymachines
                                • Mar 2011
                                • 1028
                                check all the 8 pin power mosfets , since the dc jack is on a little board and is socketed to the motherboard make sure none of those pins are mashed up and make sure its well seated, i just worked on 2 of these recently while i been busy and one was due to bad connections and the other was an reflow issue, so and i just did a Toshiba that had a bad power mosfet so there are things to check and all it takes is a hairline crack you will have a hard time seeing and that will make it malfunction check everything between dc jack all the way to battery pins and do a live test if need be but be very careful any slips can cause more problems then you started with so keep steady hands with those probes use the copper colored screw holes as your grounding point....
                                • bushido
                                  • Oct 2012
                                  • 32
                                  • japan
                                  #36
                                  thank you very much for your time i will check all those you mention thanks..
                                  • bushido
                                    • Oct 2012
                                    • 32
                                    • japan
                                    #37
                                    thank you again yeah your right i need time to find where is the bad connection thanks again for the help and advice i really appreciate..
                                      DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:36 PM
                                      DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:30 PM
                                      DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:28 PM
                                      DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
