R61i power issue
+ More Options
Posts
  • lord
    • May 2011
    • 319
    • Croatia
    R61i power issue
    I need schematic for a R61i thinkpad.
    I don't have 3V3 nor 5V, no gate voltage, no power on the MAX1540, but have 20V on FET for 3V3 and 5V. Unusual is one of the coils resistance is 18R9. Also the NB coil resistance is 5R4.
    Any advice would be very helpfull!
    Thanks in advance!
    Regards,
    Darko
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: R61i power issue
    http://kythuatphancung.com/download/...waikiki11.html
    • lord
      • May 2011
      • 319
      • Croatia
      Did any of you had the same problem?
      No 3V no 5V on the coils but 19V is on the FET?
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        1: check if the u41(max17003) get 20v at pin 21 .
        2:check if the pin 61 of u61 (RINKAN) provide the 3v necessary to activate the u41 chip
        3:check if pin4 (shdn) of u41 chip get the 3v for his activation
        4:check if pin5 and pin6 of u41 get ~3v to activate respectively the 3v and 5v that you are talking about.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • justice171
          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
          by justice171
          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
          1. Verified that all critical voltages are present:
            • 3.3V and 5V are always present if DC is plugged.
            • 1.8V on the BIOS chip is present.
          2. Checked the power button functionality:
            • When pressed, the voltage drops to 0V, indicating the button is functional.
          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
            • Confirmed connectivity is intact, ruling out issues
          11-26-2024, 12:39 AM
        • claws77
          lenovo flex 5 14itl05 power sequence issue
          by claws77
          hi guys, my motherboard will not start no matter what
          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
          but rest nothing happens no sign of life.
          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
          i have no knowledge of motherboards ....
          10-20-2024, 02:48 PM
        • yaya3gmax
          Laptop Power Issue – Works on Battery, Fails on Adapter Load
          by yaya3gmax
          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
          Symptoms:
          • Laptop works normally on a pre-charged battery.
          • Battery does not charge when adapter is connected.
          • Without battery:
            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
            • Speakers “pop” when power cut occurs indicating harsh sutdown.
            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
          08-21-2025, 07:16 AM
        • SuperJames
          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
          by SuperJames
          This one's a weird one, and still unsolved despite it having gone back to Dell once.
          Specs
          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
          Backstory
          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
          10-23-2023, 04:09 PM
