I've got an HP dv7-1232nr that has a power-up problem. It came to me like this and previous owner said it had been working fine, then suddenly started suffering the problem with no warning.
The symptom is that when you press the power button, the laptop tries to start up but shuts down almost immediately (it varies from 0.2 sec to 1.5 sec). The power adapter is fine (I used it on another HP laptop and it charged the battery A-OK). The power LED next to the jack does not light up, only for a brief flash when pulling out the plug. Also, when the plug is installed, the battery light flashes. These laptops do work even without a battery is installed (of course with the AC power plugged in), so I tried this but got no sign of power.
I had read a number of postings on-line about the dv7's problems and the most common culprit to this behavior was a bad power jack. Since it was cheap to get a replacement, I ordered one and installed it. But no joy. Upon disassembling the laptop, I did not observe any scorched components. Everything looked fine.
I ran the laptop through a number of tests. I took out the memory chips and tried to start it without them, as well as with each one individually, and this made no difference. I attached the hard drive to another computer and discovered it is 100% functional. I checked the CMOS battery and it's fine. I also tried to restore the BIOS just in case (http://h10025.www1.hp.com/ewfrf/wc/d...roduct=3860630), which did light up the AC power LED, but the process would not follow through.
On a couple of forums, I'd read about a mosfet failure that could happen in the power circuit path. I've never tested an 8-pin mosfet before. I'd assume that the source and drain is paired up directly (horizontally across). However, there's a 4th drain... so I'm not sure what's to be done with it (or if it's superfluous). The gate is the last pin on the lower left. Also, one technician who posted about a mosfet failure had said he we getting power in both directions, which isn't supposed to happen. Again, not sure how to verify this. Can anyone here explain the general process for testing an 8-pin mosfet? Thanks!
 HP Pavilion dv7-1232nr laptop power-up problem
