HP Pavilion DV5 not charging
  • nucleus
    • May 2012
    • 64
    • Montenegro
    I have this lap top and common signs "charger plugged in, but not charging"
    It could not start with battery and without charger. I measured voltages on bat, connector and there are few of them with around 3v. Is it normal and what do you think, is it charging chip or battery failed?
  • nucleus
    • May 2012
    • 64
    • Montenegro
    Re: HP Pavilion DV5 not charging
    someone must had this or similar problem???
    • zen81788
      • May 2012
      • 11
      • philippines
      try to use other adapter...i think the central pin of ur adapter is failed...
      • nish_pinto
        The Adventurist
        • Oct 2011
        • 83
        • India
        I have an HP eny15 which has a similar problem. The battery doesnt get charged and neither does the laptop run on charger. What could be the issue? I heavily speculate the charging IC or Power IC chip. Will open it up today for a closer check and then update.
        http://nishantpinto.blogspot.in/
        • nucleus
          • May 2012
          • 64
          • Montenegro
          It is not adapter because it works on it, it doesn't work when I remove it. It is or battery or charger chip
          • nish_pinto
            The Adventurist
            • Oct 2011
            • 83
            • India
            Ok guys, talking about my hp envy 15 laptop. There was a problem with the power ic -RT8206B. I reseated it with new bga solder, then re-flowed the ATI gpu and wallah! The laptop booted and worked perfectly. Details about the IC.
            http://tw.richtek.com/product_detail.jsp?s=497
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
              HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
              This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
              09-12-2024, 03:44 PM
              HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
              This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
