My Toshiba Satellite A215-S5837 has a cracked B154EW02 V.5 screen
  • Paul678
    • Nov 2011
    • 402
    But would a V.1 version be a drop-in replacement?
    It's the lowest price I found for a working unit:
    http://www.ebay.com/itm/15-4-Compaq-...item45ff1b205b
    Although it looks to have top and bottom metal tabs that are
    not included in the V.5 version......
    Thanks for any advice....
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: My Toshiba Satellite A215-S5837 has a cracked B154EW02 V.5 screen
    You can remove those metal tabs.
    I have switched lcds that weren't particularly the same "version" but worked regardless.
    • Paul678
      • Nov 2011
      • 402
      ok, thanks. I would assume the newer versions
      would supposedly be better, but perhaps not noticably.
      • Paul678
        • Nov 2011
        • 402
        Ok, so I've gotten my replacement screen:
        http://www.ebay.com/itm/250958909868...84.m1439.l2649
        And it appears to work well, except I have to set the brightness
        control to the highest setting, in order to get a good brightness.
        And the angle of viewing is rather narrow (usually the case with
        LCD, but not usually this bad).
        Is this because I didn't replace the inverter circuit (the narrow
        circuit board in the Ebay post)? Or should all inverters work
        pretty much the same? I just used the original inverter in
        the laptop.
        It's a pain in the ass to remove the screen, so I don't want to
        switch the inverter if it's not likely to improve the brightness, because the
        screen is bright enough to use, I'd just like to have a bit more
        leeway.
        Thanks in advance.....
        • thesloc
          Banned
          • Dec 2011
          • 587
          Screen brightness is usually controlled by the inverter, when a screen's light goes out it's usually the inverter so I'm guessing a new inverter could potentially make things better.
          It's either that or an aging CCFL lamp.
          • Paul678
            • Nov 2011
            • 402
            But are these inverters "matched" to each model and brand of
            screen?
            In other words, should i have used the inverter that the
            replacement screen came with?
            It didn't seem critical, because most replacement screens
            are sold without any inverters.....
            • yyonline
              • Jul 2009
              • 692
              screen?
              Yes and no. 99% of laptop screens use the same standards for connectors, voltage, etc. Odds are the inverters are perfectly compatible. Desktop LCDs are a different story altogether and don't always have interchangeable components.
              If a used screen is dim, it usually means that the backlights don't have a whole lot of life left. I find that older Samsung screens are dim, where as older LG or AUO/Quanta screens stay a bit brighter as they age. These aren't hard and fast rules, just observations I've made. You may want to let it warm up for several minutes first. It's not usually as pronounced in laptops, but some larger desktop LCDs take several minutes to reach full brightness.
              • Paul678
                • Nov 2011
                • 402
                Yes, after a few minutes, the screen is definitely brighter.
                Perhaps I'll stay away from Samsung the next time I get
                a used screen, but it's not really a problem, as it's a perfectly
                usable screen. I just wanted a bit of wiggle room, and not
                just a maxed out brightness.
                Thanks for the info....
                  Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 06:10 AM
                  Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 05:40 AM
                  09-06-2024, 05:27 AM
                  Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 08:10 PM
