4720z adaptor blink
  • boodeey
    • Nov 2011
    • 7
    4720z adaptor blink
    dear all, i need some help
    i had acer 4720z and it's totally dead
    the indicator on adaptor flash blinking when i plug it into the laptop
    is there anyone ever have same thing like me?
    please advice to repair the mainboard
    thank's
    www.servicenotebookjakarta.com
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: 4720z adaptor blink
    boodey,
    normally if the adapter blinks, it can sense a short in the mobo. capacitor, transistor or any other mobo parts that make the power adapter blinks.
    what i do if i cannot locate it with a DM, i remove the suspected part and put the charger on. if the blinks go away then, check the isolated part and compare it with other part of the same part number with your DM. (sometimes a mobo can have more than one part of the same part number.)
    i usually start the far end parts away from the DC jack. you can also try touching the parts for overheating. one way to find failed components.
    hope this helps
    thank's
    • boodeey
      • Nov 2011
      • 7
      Dm ???
      • retiredcaps
        • Apr 2010
        • 9271
        Dm ???
        Digital multimeter probably.
        --- begin sig file ---
        --- end sig file ---
          HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
          This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
          09-06-2024, 08:50 AM
        • cloo
          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
          by cloo
          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
          After doing a factory reset this problem was gone and the picture was back to...
          01-06-2025, 06:02 AM
        • EazyBone
          Un50cu7000 2 blink oddity *partially solved
          by EazyBone
          I write this to maybe help another with this TV.
          So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
          The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
          03-18-2024, 10:24 PM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
        • Vebririon
          panasonic TX-P50V10E 6 blink led problem
          by Vebririon
          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
          05-17-2025, 10:16 AM
