Toshiba Satellite Pro L40 Power issue
  • incradibles
    • Feb 2011
    • 43
    I got toshiba satellite pro l40 when i connect charger it shows death no light turn on i have checked adaptor its fine. even its not showing charging light all dead.charger light on not blinking or off.
    Silence Like Dreams
  • scobie_21
    • Jul 2011
    • 144
    Re: Toshiba Satellite Pro L40 Power issue
    Hi did you sort this outsa I have the same problem
    • mcrap
      AdvancedBF
      • Nov 2014
      • 5
      • Portugal
      Need to check the capacitors...
      • cajoeg
        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
        by cajoeg
        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
        02-10-2025, 04:01 PM
      • justice171
        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
        by justice171
        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
        1. Verified that all critical voltages are present:
          • 3.3V and 5V are always present if DC is plugged.
          • 1.8V on the BIOS chip is present.
        2. Checked the power button functionality:
          • When pressed, the voltage drops to 0V, indicating the button is functional.
        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
          • Confirmed connectivity is intact, ruling out issues
        11-26-2024, 12:39 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • russpall
        LG 39ln540v - red light flashes twice, no power to LED driver?
        by russpall
        Hi there,
        I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
        The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
        08-27-2024, 01:07 PM
      • yaya3gmax
        Laptop Power Issue – Works on Battery, Fails on Adapter Load
        by yaya3gmax
        Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
        Symptoms:
        • Laptop works normally on a pre-charged battery.
        • Battery does not charge when adapter is connected.
        • Without battery:
          • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
          • Speakers “pop” when power cut occurs indicating harsh sutdown.
          • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
        08-21-2025, 07:16 AM
