samsung r20 power fault
  • woodford
    • Jun 2011
    • 27
    i have a samsung r20 that has no signs of life.i stripped it down and there is power getting to a few parts of the board and nothing showing shorted.i tested the standby voltage at the power switch and there is no voltage on all 4 pins.is the maxim chip responsible for supplying standby voltage to the power switch?ive reflowed the maxim but still the same.
  • rajukh3
    • Sep 2011
    Re: samsung r20 power fault
    on off switch oprait with transister find transister & replace then your problem solved
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • hill01
      Samsung UE75MU7009TXZG Endless Power Cycle
      by hill01
      Hi everyone and thanks in advance for any help I might get here
      My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
      About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
      Since a few days, the TV won't turn...
      11-17-2021, 02:52 PM
      03-31-2024, 02:12 PM
    • cheeky2
      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
      by cheeky2
      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
      06-15-2025, 05:12 AM
