Toshiba Satellite L300 Wont work with charger
  • incradibles
    • Feb 2011
    • 43
    I got toshiba satellite L300 when i connect only with charger it gets restart, it works with battery but when i connect charger it get off
    Silence Like Dreams
  • TimB52
    • Jul 2011
    • 5
    Re: Toshiba Satellite L300 Wont work with charger
    My bet would be the charger connector is bad. Toshiba Satellites are rather notorious for this issue. Fortunately, the L300 connector is easy to replace as you don't have to solder anything. Go to eBay and search for: DC JACK W CABLE TOSHIBA SATELLITE L300
    Tons of them available. $2.50 with free shipping even.
    • juus
      • Jul 2011
      • 17
      Would be lucky if it didnt bugger anything on the charging circuit on the motherboard.
      Connector was my first check & replaced it even though tested good, but now problem on board.
      • Wizard
        • Mar 2008
        • 2296
        PLease describe the behavior of the charger. Did charger "shut" down when attempted to use with the notebook? So on. If this is in case, there is a bad shorted IC somewhere near by. I had to locate MOSFET transistor with ohmmeter and replace with compatible one. Be aware in these design they always parallel with another at least 2 or three so pick one and desolder it. Chances you get right one or wrong one.
        Cheers, Wizard
        • incradibles
          • Feb 2011
          • 43
          Charger remain on means when i press on button all light gets on later only only charger light remain on and rest gets off. laptop goes to off
          Silence Like Dreams
          • incradibles
            • Feb 2011
            • 43
            I got the solution under cpu there is a square caps Market nec... remove it and put small tiny rectangular caps
            Silence Like Dreams
            • ferryvanhot
              • Aug 2011
              • 7
              that's right.. i use same metode and sofar sogood... i use 4x330uf smd
              • andy45
                andy45
                • Sep 2011
                • 4
                Hi I'm new to this forum and I have the same problem with my L300. I took a picture with the part labeled NEC TOKIN capacitor and I would like to confirm with you if this is the one? If so, can you show us how you soldered those smd caps on the board. This is to give me some guide once I desolder this part. If there is no need to remove this part then how did you solder those smd caps correctly? Hope you can enlighten me on how you did it. Thanks in advance from Manila, The Philippines.
                • fabiog
                  • Jul 2011
                  • 102
                  you can find the instructions here:
                  https://www.badcaps.net/forum/showth...highlight=l300
                  I also successfully fixed my L300.
                  • andy45
                    andy45
                    • Sep 2011
                    • 4
                    Thanks for the info. Really appreciate it. Now I can try it this weekend and hope it works.
                      Toshiba Satellite Pro L300-156 Notebook Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro L300-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L300-156 boardview and L300-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                      09-06-2024, 05:27 AM
                      Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 06:10 AM
                      Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 05:40 AM
