compaq cq41 dead
  • lcrcron
    • Mar 2011
    compaq cq41 dead
    hi all, I have a compaq cq41 dead, no indicator when power on, led indicator when power adapter plugged also dead.
    anyone have a solution
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: compaq cq41 dead
    Did you check power supply? It may be a power jack or power supply.
    Laptops and computers repair.
    • mattbrad2
      • Jan 2011
      • 122
      So you've verified the charger is working properly? Does the charger short or go into protection mode when plugged in to the laptop?
      EDIT: looks like gabik111 beat me to it.
      • lcrcron
        • Mar 2011
        charger works fine on another laptop and the battery works fine too
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          If the DC jack is on its own little PCB, check the jumpers from it to the motherboard for breaks/bad solder. Check power MOSFETs for shorts.
          I had a Samsung 42" LCD TV where the backlight failed. The backlight enable pin to the inverter never was soldered! Just the bare copper via... the terminal's pin loose in it. A friend got it from craigslist cheap, and a little solder later, it was fine.
          -Paul
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • gabik111
            ORD spotter
            • 142
            • USA / Poland
            So if the battery works you'll need a schematic a remove laptop apart. Then study on diagram and closer look on mobo. Looks like kaboom is right about power transistors on charging/power distribution section.
            • nish_pinto
              The Adventurist
              • Oct 2011
              • 83
              • India
              How to check if mosfets are short?
              http://nishantpinto.blogspot.in/
              • sasser
                • Dec 2012
                • 364
                • Malaysia
                i also had the problem no power compaq CQ41. no light at DC jack light indicator. check power jack got 18.5 its correct. but no power to board and cpu. vccore no value. anyone hav the schematic diagram of compaq cq41? what mosfet hav to check and where to
                • opamp
                  • Dec 2012
                  • 160
                  • united states
                  Actually vcc core voltage will not be present by just plugging in the ac adapter. You should check for 3 and 5 volts Always on first. 3.3 volts should be present on the power button at all times.
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    oh ok. vccore no present value when pluggin ac adapter and i check power button got 3 volt. what u means "You should check for 3 and 5 volts Always on first" where to check
                    • opamp
                      • Dec 2012
                      • 160
                      • united states
                      There's a voltage regulator that produces 3 and 5 volts when you connect the power adapter. It's called always on because it should be present without pressing power button. Try and find the schematic so you will have a better understanding how power is distributed. More than likely you have a shorted component. Check mosfets and capacitors out of circuit.
                      • siddiq
                        • Dec 2011
                        • 121
                        • Ghana
                        Do you have the schematic? So we can proceed from there.
                        • sasser
                          • Dec 2012
                          • 364
                          • Malaysia
                          i dont hav shcematic diagram. already replace ati bga but still no display.that the others thing must chech to determine the gpu is ok or not. some value present at the capacitor below cpu pads?
                          • survey
                            • 16
                            • Portugal
                            I have two schematics for this laptop, both from COMPAL: la-4106p and la-4107p
                            • madank
                              • Jun 2014
                              • indonesia
                              thanks 4 schematic
                                HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:44 PM
                                HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                09-12-2024, 03:36 PM
                                HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:30 PM
                                HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
