Dead Thinkpad R30 and R31 series.
  • Wizard
    • Mar 2008
    • 2296
    No burn or shorts, and voltages measures OK on everything. This is mysterious failure. The seller tested used motherboards and I bought one to rebuild a R31. Dead. Send it back for another. Got second board in. Still dead.
    Anyone have figured out why high mortality of R30/R31 series is happening all over?
    Notes what I have done:
    No memory error beeps (this is a trick used to confirm CPU and chipsets are fine). Even the status LEDs on the LCD did not blink for a second every time power button is pressed.
    Tell me if anyone who is using Dell C400, C510 and C610 all are same 830MG, 133FSB and up to 1GB ram are still alive and long life? This chips features are also found in R30/R31 as well. only difference is northbridge is not cooled at all in that thinkpad, while Dell used big pressed heatsink plate with deep dimples and thermal pads on all major chipsets.
    Cheers, Wizard
  • Fluval
    Mr Fix-IT
    • 10
    Re: Dead Thinkpad R30 and R31 series.
    Hi Wizard
    Is the standby voltage present at the power switch - I assume you checked this but just need to know.
    Have you tried another CPU lower spec just in case the Bios revision of the new MB might not support your current processor. Also some makes of laptops wont power on without the CPU.
    Have you removed the Cmos Battery?
    Try Disconnecting everything except CPU & Ram.
    I know the above are fairly basic checks but you never know
    Hope this helps
    Fluval
    • Wizard
      • Mar 2008
      • 2296
      Fluval,
      I have. The power button responds is nature of this southbridge along with power management chipset.
      I have 2 CPU, celeron 1.2GHz (came in one of them) and two PIII-M 1.13GHz that is supported by mainboard. Did not beep at all without memory. The
      LED status *should* had been blink about 1 second then running. This did not, all I get is very short flash. That's not right.
      Recall that I checked all voltages, all are there for chipset as I was famillar with stuff of the time: 5V, 16V, 3.3V, 2.5V, 1.5V, and CPU different voltage (usually two voltages) etc.
      Cheers, Wizard
      • Fluval
        Mr Fix-IT
        • 10
        What's your MB Part number ?
        • Fluval
          Mr Fix-IT
          • 10
          See attached - check this Cap
          • Wizard
            • Mar 2008
            • 2296
            I did google searches and I did find that one as well. This does not match the symptoms. That little cap prevents turn on. The two boards does turn on.
            Even I did mention that I used scope to look at signals, it is not running on memory bus that proves something major failed in northbridge or southbridge. I also did looked at bios chip for signal. Not there either.
            I also looked at the IBM service manual and carefully checked and these boards supports the configuration I desired.
            Cheers, Wizard
            • 12ax7a
              • Oct 2009
              • 21
              i have an acer aspire 4530 with very similar symptoms.. hmmm. wonder what these mobos may have in common. like perhaps the embedded power controller? ... WPCE775C? this thing is only 2.5 years old.. very strange.. 5v & 3v standbys are there .. still checking other test points. i wonder why they singled out that cap.. is it under-rated for that spot?
                ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 03:28 PM
                ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
