Toshiba Satellite A300
  • sas01stephen
    • Mar 2011
    Hi all, I'm new to this site/forum and require some advice and help if anybody can. I have a Toshiba Satellite A300 that shuts down when i try to load OS but most the time doesnt even get that far! also when you start up the laptop it will black screen when power adaptor is plugged in, but start ok when running off battery but when PSU is plugged in shuts down straight away!!. The battery will also charge ok when charger is plugged in. I stripped lappy down and cleaned with surgical spirits and compressed air and started again which made no difference I also removed all other components ie dvd drive etc and started it up and same again so it deff a Mobo fault . There did look like liquid had been spilled near CPU and when the laptop shuts down the heat seems to be concentrated around the 2 Grey Components next to CPU marked R36W 4C 8N31J. I'm not fantastic with computers and the terminology but do have some electrical/computer background but please treat me as a pure amateur, I dont want to give this up as a bum deal so any help would be greatly appreciated thanks very much Steve
  • dobber
    • Jul 2008
    • 83
    Re: Toshiba Satellite A300
    Does it turn off when you plug in the power adaptor. If it does, sounds like a direct short somewhere. Does it have the original power adaptor? I have got a couple of toshibas off of ebay that had power issues caused buy after market power adaptors, not having enough amps to power them properly.
    • sas01stephen
      • Mar 2011
      Hi dobber, yes the lappy does turn off when power adaptor is plugged in, the adaptor it came with was the wrong adaptor so I got a original toshiba adaptor but made no difference the lappy still turns off. From what Ive read up online the damage could be with the Voltage regulator circuit or chip??? not too sure where this is or what it looks like but as Ive already said it seem to be the 2 grey square caps/chips next to the CPU that are red hot when the laptop shuts down. Do you have any other info that I could look into or possibly try??? thanks for you time
      • ozcomputerguy
        TOSHIBA A300 shuts down when DC plugged in (work around)
        Ok well we seem to have got close to a solution with one the same here in the workshop.
        I'D LIKE SOME INFO IN EXCHANGE PLEASE. Q: Does your A300 boot in safe mode when DC jacked in ?
        Also I am assuming like me you have done all the Fan and cooler maintainance.
        Boot with battery, disable in device manager the processor drivers.
        Reboot with DC jack in.
        Did this work for you ?
        We are now trying BIOS update and Processor driver updates, My guess is that when OS is controlling the Processor upon power profile and cpu throttle up on DC the system fails. Maybe it's already had as much heat damage as it can take. Like underclocking some RAM when its leaking we found this "Workaround"
        You owe me some Proper feedback now please
        cheers
        OZCOMPUTERGUY
        • ozcomputerguy
          See ozcomputerguy post reply to sas01stephen A300 DC SHUTDOWN
          Cheers
          • infringer
            Badcaps Member
            • Sep 2009
            • 244
            • United Frickin States
            MODERATE -> To laptop section
            Great post but lets keep the forums clean and post in the proper sections.
            Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
            • jtamad44
              • Apr 2013
              • 145
              • israel
              Hi, did you fix the toshiba satellite a300?
              • marcellodj
                • Nov 2010
                • 99
                tokin supercRap
                • oksorin
                  • May 2013
                  What model A300?
                  • jtamad44
                    • Apr 2013
                    • 145
                    • israel
                    I already fixed it, i changed the nec/tokin with three 330uf 2.5v.. its workin fine now..
                      Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                      09-06-2024, 05:27 AM
                      Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                      Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                      Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 06:10 AM
                      Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                      This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 05:40 AM
