V3000 Intel No Display At LCD But Got Display On External Monitor
+ More Options
Posts
  • snsent
    • Nov 2010
    • 103
    • Malaysia
    I got 1 unit V3000 Compaq mobo. The problem is, No display on LCD panel but got display when I connect it to external monitor. Anyone can help me?
    Regards
  • ablacon64
    • Jan 2011
    • 89
    Re: V3000 Intel No Display At LCD But Got Display On External Monitor
    More details, please. Have you checked flat cable, flat cable connector, etc? How is the chipset temperature?
    • chevelle_nut
      • Dec 2008
      • 62
      If you shine a flashlight on screen can you make out an image ? Try moving cursor and shine light in area it should be displayed in (same area as external monitor). If you see anything you have a bad inverter or ccfl. Inverter is an easy fix. CCFL, not so much...
      • snsent
        • Nov 2010
        • 103
        • Malaysia
        I already checked a flat cable and flat cable is OK. This model is using Intel chipset and temperature for chipset is only warm and not getting too hot. Already tried to use another LCD, inverter and flat cable but still got no display and no backlight.
        • ablacon64
          • Jan 2011
          • 89
          Check LCD flat cable connector solder (on motherboard), look for cold joints.
          If you already tried LCD, inverter and flat cable, and are sure everything is alright with them, you should check voltage on the inverter board. It has to have about 18.5v (equivalent to the ac adapter voltage), 5v and 3v or 3.3v.
          If you don't have the voltages, check components U11 and U10. If everything is alright you'll probably have to reflow or reball the GPU. Post your tests.
          • snsent
            • Nov 2010
            • 103
            • Malaysia
            Component U11 & U10 is 8 pins IC. This is V3000 Intel mobo. Are you sure I need to reball / reflow Intel GPU?
            • ablacon64
              • Jan 2011
              • 89
              I have had some cases like this that reballing did the trick.
