Toshiba A135 Laptop problem
  • mandacat
    • Apr 2009
    • 7
    Toshiba A135 Laptop
    Symptoms:
    Starts, but will not post. Both the Hard Drive and Optical Drive lights remain on, but no action on either. Battery will charge and will also exhibit same as above on AC power with Battery removed. The cooling fan runs and the CPU gradually gets hot.
    Found one of the Power Rails with NO voltage at the output of its associated inductor. It is the rail being driven from an ISL6269ACRZ Controller, which in turn drives the Mosfets (a 4800 and 6690AS). I'm not sure what the voltage should be, nor what this rail feeds – could be 1.05 volts, but has to be between .6v and 3.3v as that's the ISL6269ACRZ spec. The rail measures 22 ohms to from inductor to ground, with the feed side of inductor disconnected from the Mosfets.
    Don't know if I should look for a short in the output or troubleshoot the Power rail Control Circuit.
    Any ideas would be appreciated.
  • mandacat
    • Apr 2009
    • 7
    Re: Toshiba A135 Laptop problem
    Thought I'd get some ideas - anyone ? Pyr0Beast ?
    I've attached some pics
    mandacat
    • borbooroski
      • Mar 2014
      • 177
      • Ghana
      I have this same problem can someone help get solved it Thank folks.
      • atsio
        • Oct 2013
        • 819
        • Greece
        It's for the 1.05v rail. Give voltage on all pins of PU8.
          09-06-2024, 05:27 AM
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
          09-06-2024, 05:59 AM
