Toshiba A200 freeze while plug to AC
  • Ch1p4@ll
    Newbie
    • Mar 2010
    • 19
    need help on Toshiba A200 freeze/won't power-on while plug to AC, but fine while use battery.
    Things i do:
    -replace RAM
    -reinstall System
    -replace HDD
    But all Fail! what i need to do now?
    Plzzz give me a hint...
    Thanks u...
  • mockingbird
    • Dec 2008
    • 5484
    Re: Toshiba A200 freeze while plug to AC
    My Toshiba adapter did eventually die, could be your adapter is dying.
    • Ch1p4@ll
      Newbie
      • Mar 2010
      • 19
      Thanks for reply
      but i have tried new adapters, even the higher Ampere adapter.
      i googling n found that, a lot of same problem as mine on Toshiba "AXXX" series. but still no cure...
      • mockingbird
        • Dec 2008
        • 5484
        I have no such problem. It runs very well. Can you please show me the picture of the type of adapters you are trying? I hope it's not those cheap ones off eBay.
        Before my old (original) adapter died, I started getting BSODs in Vista.
        Another thought occurs to me, when you are in battery mode, your Intel Wireless switches to Power Saving Mode... There are versions of the Intel Wireless drivers that crash Windows, so it could be that is is happening during CAM (Constantly Aware Mode). Try updating both your Windows INF drivers (Infinst - make sure to get the latest version) and the latest Intel wireless drivers.
        • Ch1p4@ll
          Newbie
          • Mar 2010
          • 19
          Thanks u...
          it's not a cheap one... bought from the toshiba store. n i have tried the old one on other toshiba, it work fine.
          i search n found that they said something wrong with the "NEC/TOKIN 0E128" Capacitor.
          then ok! i disassembled my lapie...found the NEC/TOKIN, then i measure the cap... it is 1200uF++ (nothing wrong)...
          • seanc
            • Nov 2008
            • 1319
            I had a customer with one of these a couple of years ago, all I could suggest at the time was to use it without the battery, motherboard replacement would not have been worthwhile.
            • Ch1p4@ll
              Newbie
              • Mar 2010
              • 19
              it can charge abnormally to battery (can charge about 30% n it stop, even a new batt)
              it can be use normally with battery, when plug to AC the windows freeze.
              if i plug from the beginning... it will turn on n then turn off again (only the led lid n off again).
              • seanc
                • Nov 2008
                • 1319
                What does it do with the charger plugged in, without the battery?
                • Ch1p4@ll
                  Newbie
                  • Mar 2010
                  • 19
                  Can turn on, only on for 3sec (like normal on, fan, hdd read led) then off again
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    I have a Toshiba A205, and if I try to run it without the battery it boots to just a cursor. I don't remember if the BIOS screen appears first.
                    I don't know why your battery charges only to 30%, but maybe you need to recalibrate the charging (Control Panel entry).
                    Have you tried IrisVista.com, a website that specializes in Toshibas? There's also NoteBookReview.com, for notebook computers in general.
                    • Ch1p4@ll
                      Newbie
                      • Mar 2010
                      • 19
                      WOW! thanks...i will check the site
                      • Ch1p4@ll
                        Newbie
                        • Mar 2010
                        • 19
                        OK! problem solved... i just need to re-soldering the "Maxim IC" (48pin) near the vga-out Line. n everthing work fine now...
                        • Volkymaniac
                          • Jun 2011
                          • 9
                          Hi Ch1p4@ll
                          I need to know how do you know that IC is the problem???? How do you know that the problem is not the Nec/Tokin???? I have an A205-5804 with the same issue, I order a caps 330UF to replace the Nec Tokin, but Now u make me thinkikng if is the nec/tokin or the Maxim IC. Re-solder the IC is most easy than replace the nec tokin with 330UF caps??????????
                          Please let me know if u can help me with this issue with any comment, suggestion, Thanks
                          • infringer
                            Badcaps Member
                            • Sep 2009
                            • 244
                            • United Frickin States
                            Well the Maxim IC would be a great place to start as it would likely regulate the voltage for the charging circuit.
                            Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                            • fabiog
                              • Jul 2011
                              • 102
                              I have same problem with toshiba L300 ,what does the Maxim IC" (48pin) look like and how to measure the NEC/Tokin with multimeter?
                              I also get a hissing/buzzing sound when I plug in the charger.
                              Thanks.
                              • ferryvanhot
                                • Aug 2011
                                • 7
                                Thanks.
                                it's come from the nec/tokin... try to change the caps with 4x330uF smd...
                                • raizenn27
                                  • Jun 2011
                                  • 97
                                  • philippines
                                  i agreed with ferryvanhot i have the same problem and the same solution to the nec tokin..and it works fine..but in my case only 3x 330uf /2.5v smd i used ..cause the nec tokin is 900uf / 2.5v only so i just try it that way..and it works fine..
                                  • fabiog
                                    • Jul 2011
                                    • 102
                                    Did you only solder the 3 caps (2 on one side and 1 on the other?) I thought you needed at least two on each side.
                                    • red_raian
                                      • Aug 2011
                                      • 14
                                      i used 4X330uf and works good so far.. check first the positive before putting caps..
                                      • raizenn27
                                        • Jun 2011
                                        • 97
                                        • philippines
                                        yes 2 on the other side and 1 on the other..,i also encounter a toshiba w/ poadlizer cap on it but the name is not nec tokin.,its only the capacitance value and voltage..,and i do the same like i did with the nec tokin caps and its working...
                                          Toshiba Satellite Pro A200-1MV Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1MV can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1MV boardview and A200-1MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
