Toshiba satellite a105 with no display
  • niki1
    • Nov 2010
    • 14
    Ok, hope this is correct.
    Hi, I was using the laptop Tuesday evening, and left it on and open. Wednesday showed only a black screen. I have tried power on and off, and get the first three led's lit, it sounds like it wants to boot, but then nothing on the screen. I have tried without the battery, without the ac cord, and also hooked it up to an external monitor and rebooted, but nothing. Toshiba said it is a hardware issue, not in warranty, and $175 minimum to look at it. Is there anything that I can check first?
    Thanks,
    niki1
  • jetadm123
    • 2169
    Re: Toshiba satellite a105 with no display
    Hello and welcome to the forums! With the laptop turned on in a dim room, try shining a flashlight against the dark screen. If you see a faint image, then it could be caused by a bad inverter assembly or bad backlights.
    Also, other possibilities include:
    bad or poorly seated video card, if video card is separate from motherboard
    bad memory or cpu
    bad motherboard
    loose connection between LCD screen wiring harness and motherboard or video card
    • niki1
      • Nov 2010
      • 14
      Thanks. Tried the flashlight, nothing. Stopped in to bestbuy where I bought it, and geek squad said probably the motherboard, and since computer is 4 years old, he said it was too expensive to fix. I would like opinions from here.
      • Wrog
        • Oct 2009
        • 472
        While I wouldn't personally trust anything Geek Squad tells you, this is likely the correct diagnosis from your description. If you're comfortable with replacing the motherboard yourself, you can get a "New" one from eBay for $45 shipped. Obviously, make sure you double check it's the right one because there seems to be a few different versions of the A105.
        I think it's worth it to try and fix -- my personal criteria on laptops is if they have a widescreen LCD, then it will be in demand.
        • jetadm123
          • 2169
          If you do go the motherboard route, you can try searching for one on ebay using the full model # A105-SXXX. However, since different motherboards may have been used, the ideal method is to take the laptop apart and look for the factory part number, V0000XXXXX. Some of the boards can get very pricey and it really only makes sense if you do the work yourself. And if you have never done this type of work before, it can be a bit overwhelming.
          • niki1
            • Nov 2010
            • 14
            Thanks for the advice. I will do some research, and see what I find.
            niki1
            • niki1
              • Nov 2010
              • 14
              Just another thought. First off, I have been reading some faq's and posts, and while a lot of it is over my head, I really like and appreciate this site. Is there a way to know if my motherboard would benefit/repair itself with recapping, or am I still better off to look for a new motherboard?
              • Wrog
                • Oct 2009
                • 472
                Laptop motherboards are almost an entirely different animal than desktop motherboards. There is a very low probability that your problem is due to bad caps, because laptop motherboards are almost entirely surface mount. Surface mount caps don't go bad as often as electrolytics do, and when they do go there is usually some visual evidence. It won't hurt to open the laptop up and check!
                I would venture to guess in your case, you would need a replacement GPU (which requires special machinery if it is soldered directly to the motherboard). If you want to post pics of the motherboard, we can verify it. If you can post the entire model number (as jetadm123 says, A105-Sxxx), that would give us more clues too.
                • niki1
                  • Nov 2010
                  • 14
                  Thanks. I will do that. I just like the idea I get from this board, that not everything has to be thrown out , or large components replaced for a .30 item! Less expenditure, and less in the landfill. It will take me awhile to take it apart, but I will post pics. My model #is #PSAA8U-0FH02K and the ser# is y6242926q
                  • niki1
                    • Nov 2010
                    • 14
                    Ok, started to open the laptop. Wow, the ribbon connectors are sure short. Is there any reasonably easy way to detach and reattach? It looks like reattaching will be the worst. I will take pictures and post when it is fully open.
                    • Wrog
                      • Oct 2009
                      • 472
                      Most FFC (flat flex cable) connectors have a bit of plastic that swings up perpendicular to the PCB, and they are usually pretty fragile (and hard to replace!). Good idea on the pics beforehand!
                      • jetadm123
                        • 2169
                        Try this link, the photos are already taken for you:
                        http://www.irisvista.com/tech/laptop...herboard-1.htm
                          • 30979
                          lift the keyboard up and the dark brown bit on the connecter lifts a couple of mm to release the cable.
                          (i have an a100)
                          remove the harddrive & wifi card & see if it works before you strip it.
                          i'v seen faulty sata drives stop laptops dead in there tracks.
                            09-06-2024, 05:27 AM
                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 06:10 AM
                            Toshiba Satellite Pro Satellite Pro A30-D-10E Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro Satellite Pro A30-D-10E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A30-D-10E boardview and Satellite Pro A30-D-10E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 05:35 AM
                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 05:40 AM
