A1989 820-00850-A - No Image on internal LCD
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    Hello all, i have one A1989 that is working fine but internal LCD is not showing anything (to me it looks like no image). When i connect external LCD i can operate system and work like normal, just internal LCD is not working
    There was burned connector on LCD and also the flex was burned.
    On repair wiki i've found that there should be U9850 that is responsible for this but i don't see this IC on board (checking schematics and there is no component with name U9850)
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: A1989 820-00850-A - No Image on internal LCD
    No GMUX on boards without dGPU. Almost always damaged CPU eDP output after backlight power rail arcs with eDP AUX line.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      I've just checked J8500 and Pin 1 EDP_INT_AUX_N in 0V (in diode mode)
      Does this mean that it's unrepairable and macbook can be used only on external screen ?
      • reformatt
        • Feb 2020
        • 1451
        Yes, unless you replace the CPU. Louis Rossman has been very critical of this design decision by Apple. It's a very common fault.
        • Madoy104
          Macbook Pro A1989 - No image, working fine with external monitor
          by Madoy104
          I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
          08-15-2024, 10:01 AM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • Dallas90
          Macbook A1989 - No display/image
          by Dallas90
          I need your help with this repair that I’m working on at the moment, it’s a Macbook Pro A1989 board number: 820-00850A.
          When i got the laptop from the customer the laptop just booted up with the charger connected but with no display or backlight.
          i found out that the charging ports were slightly burned so i replaced it but the fault was resolved, so my next step was to check the board and found out that
          both charging Ic’s was faulty and i ordered 2 new ic’s and replaced them.
          After i replaced the ic’s the laptop boots up and keep...
          08-02-2024, 03:48 PM
        • iMuhtaseb
          iMac 21.5 2017 4K no image on internal screen
          by iMuhtaseb
          820-00597
          iMac 21.5" A1418 2017 4K is not showing an image properly.. It shows an image externally without issues but to the internal screen it's intermittent.
          Another screen results the same thing, it's a main logic board issue.
          I had doubts about the LVDS connector so I replaced it, still the same issue..
          The main logic board diagnostics LEDs are 5.. #1, #2, #3 works OK but #4 is half on and #5 is off.. I don't know what #4 means while it's not completely off or completely on..
          Anybody having an idea or seen this...
          09-19-2022, 07:11 AM
