I need your help with this repair that I’m working on at the moment, it’s a Macbook Pro A1989 board number: 820-00850A.
When i got the laptop from the customer the laptop just booted up with the charger connected but with no display or backlight.
i found out that the charging ports were slightly burned so i replaced it but the fault was resolved, so my next step was to check the board and found out that
both charging Ic’s was faulty and i ordered 2 new ic’s and replaced them.
After i replaced the ic’s the laptop boots up and keep running even if removed the charger, but the display is still dead…
then i started to take some measurements on the LCD connector and i think a found a abnormal reading, on pin 1 the reading should be 0.226 according to
Paul daniels boardview software, but on my board i following readnings: 0.002 diode mode and 2.6 in ohms mode.
So my questions if anyone got any ideas what the fault could be? What i could see is that pin 1 is directly connected to the CPU
Is there anything else that i could check or do?
I would really appreciate your expertise guys.
Thanks in advance.
Thanks in advance.
