gu603zx Mosfet replacement help
  • Kiajalali
    • Jun 2017
    • 7
    Basically I am looking to replace a P channel Mosfet called RQ3E120AT, I found SM3307PSQG but specs are a little different. Please give me some help on this one, or let me know what specs should I be looking for.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: gu603zx Mosfet replacement help
    The package should be same. Pulsed drain current should be equivalent or higher.
    • DoOm86
      Dual mosfet replacement help
      by DoOm86
      Hello.
      I have a notebook with a shorted mosfet, it's a E6930 GA8125.
      It seems to be a 30V dual asymmetric N-channel AlphaMos.
      Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
      And here is where I need help!
      It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
      I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
      Thanks!...
      10-31-2023, 12:03 PM
    • jm942
      Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
      by jm942
      My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
      I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
      I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
      I did voltage injection on the cpu with 0.7V and i have a current...
      07-11-2024, 05:11 AM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • String2016
      SMD MOSFET REPLACEMENT
      by String2016
      Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
      01-23-2025, 06:35 PM
    • String2016
      by String2016
      i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
      12-15-2024, 05:31 AM
