FH51M LA-J871P charging issues
  • reparetech
    • Mar 2021
    • 11
    Hi, I have this Acer Nitro FH51M LA-J871P that intially came in because it did not turn on at all.
    Short detected on +19VB which turned out to be PC1105 shorting +19VB_1VALW. Capacitor removed and replaced.
    Now, the computer turns on (on charger, and on battery), but it does not charge and the charging light flashes after about a minute.
    What has been done:
    - PUB1 has been replaced, didn't change anything.
    - Changed battery, didn't work
    - Changed charger, didn't work
    - Updated BIOS (When it was updating, the charging light stayed on, but started flashing afterwards, not sure it if actually charged anything, as the battery still said 26% in Windows before/after)
    I verified that the RTC battery is at 3V and +RTCVCC is 2.92V
    Measuring PJP201: pin 1-2: 0V, pin 3: 3.15V, pin 4: 3.18V, pin 5: 0.150V, pin 6: 0V, pin 7-8: 15.920V,
    Measuring PQB2, pin 1-3: 15.920V, pin 4: 15.822V, pin 5 measures 19.158V.
    If anyone had any input on what to look for next, that would be great !
    Thank you !
    [MOD EDIT]
    Link to Schematic + Boardview https://www.badcaps.net/forum/showthread.php?t=106787
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
  • mon2
    • 14666
    Re: FH51M LA-J871P charging issues
    Hi.
    1) You have posted the schematics in this forum instead of the dedicated schematic forum. @SMDFlea may force you into a labour camp to have you desolder plugged vias of a multilayer PCB with a 15W soldering iron as a form of a punishment.
    2) Be sure the battery is a known good battery. Does not hurt to order one from Amazon for a quick confirmation. Can be returned if not required.
    3) The charger IC should be reviewed. Carefully measure the voltage to ground of pins 19 / 20 (SRN / SRP) on PUB1 with the power adapter and also the battery connected. In general, a good idea to measure (carefully) the voltage to ground of each pin on this charger IC for a review. Post each measurement.
    • reparetech
      • Mar 2021
      • 11
      Originally posted by mon2
      Hi.
      1. Sorry, I posted the schematics to help people who would want to dianose the issue.
      2. I have actually tried two batteries. Started with a non-original one and then ordered an original Acer battery. Same issue.
      3. Pin 19: 15.938V, pin 20: 15.938V Also measured 20.1 ohms between pin 19 and 20.
      Thank you very much for your help.
      • mon2
        • 14666
        These measurements look fine.
        Best to measure the voltage of each pin on this charger IC to better understand what the component is or is not doing.
        For example, is the charger IC being powered?
        ACOK?
        ACDET?
        Voltage to ground of EC_SMB_DA1? EC_SMB_CK1?
        • reparetech
          • Mar 2021
          • 11
          these measurements look fine.
          Best to measure the voltage of each pin on this charger ic to better understand what the component is or is not doing.
          For example, is the charger ic being powered?
          Acok?
          Acdet?
          Voltage to ground of ec_smb_da1? ec_smb_ck1?
          1: 18.960v
          2: 19.157v
          3: 19.729v
          4: 19.727v
          5: 3.295v (acok)
          6: 2.593v (acdet)
          7: 1.903v
          8: 0v
          9: 0v
          10: 0v
          11: 3.180v
          12: 3.198v
          13: 0v
          14: 0v
          15: 0.151v
          16: 0.107v
          17: 15.927v
          18: 15.913v
          19: 15.926v
          20: 15.926v
          21: 1.045v
          22: 0v
          23: 0v
          24: 6.042v
          25: 15.646v
          26: 15.780v
          27: 15.927v
          28: 19.390v
          ec_smb_da1: 3.190v
          ec_smb_ck1: 3.201v
          I don't know much about how this IC works, so I might be wrong, but the only thing that looks weird to me is how BATDRV is not 6V above BATSRC to turn on the FET.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I think you mean ACDRV not working. Theoritically,ACDRV should work when VCC+CMSRC is present and ACOK is pulled high. Since all the conditions are met,it should be 25V approx.
            I doubt your readings on pin1-2 of charging IC-it should be practically same(may be PRB3 damaged).PQB3 and/orPQB4 is very likely shorted /leaky.
            • reparetech
              • Mar 2021
              • 11
              Sorry, I must have had a finger on the probe, pin 1 actually measures 19.069V. With that measurement, iadp (pin 7) seems to make a lot more sense.
              While battery and charger are plugged in:
              PQB3:
              Pin 1-3: 19.739V
              Pin 4: 19.733V
              Pin 5: 19.740V
              PQB4:
              Pin 1-3: 19.739V
              Pin 4: 19.733V
              Pin 5: 19.158V-19.161V
              PRB3:
              Pin 1-2: 19.158V-19.161V
              Pin 3-4: 19.158V-19.161V
              PRB3 fluctuates constantly
              Is it safe to assume +19V_P2 (pin 5 of PQB4) should be higher and that I should try replacing PQB4 ?
              • mon2
                • 14666
                Pin # 4 = GATE voltage to ground of the DCin mosfets (PQB3 & PQB4) are in question.
                To enable these N-channel mosfets the GATE voltage should be higher than the voltage being passed between source & drain pins.
                So gate voltage should be = adapter voltage + REGN voltage (~6 volts) = 19v + 6 volts = ~25 volts to ENABLE each N-channel mosfet.
                Since the gate voltage is NOT this boosted voltage yet the voltage is passing through, the mosfets are of concern. As per the sticky above by @Piernov, usually the bad boy is @ PQB4 (2nd DCin mosfet).
                Remove all power. Meter in resistance mode.
                Measure the resistance across the mosfet pins to check if they are leaky.
                Measure:
                source (1-2-3) & drain (5-6-7-8)
                source (1-2-3) & gate (4)
                gate (4) & drain (5-6-7-8)
                Post each measurement for PQB3; PQB4. If you see 'OL' on your meter, then switch to a higher meter scale (unless it is auto select). Post also the units of the scale (ie. K ohms, etc.).
                A low resistance = mosfet is defective.
                • reparetech
                  • Mar 2021
                  • 11
                  Measure:
                  Thanks. The sticky is exactly what I read, I unfortunately missed the part about the gate voltage though.
                  PQB3:
                  S-D: 0.20 ohm
                  S-G: 2.08 Kohm
                  G-D: 2.90 Kohm
                  PQB4:
                  S-D: 0.280Mohm and growing (39.32 Kohm measured in reverse)
                  S-G: 2.09 Kohm
                  G-D: 0.260 Mohm
                  Removed PQB4, PQB3 short between source and drain is still present.
                  Thermal camera (before the mosfet was removed) showed no shorted caps anywhere, so I can safely assume PQB3 is bad ?
                  • mon2
                    • 14666
                    Yes, remove PQB3 as well and check if the short is gone or not.
                    • reparetech
                      • Mar 2021
                      • 11
                      Thank you @mon2 and @mcplslg123. PQB3 is indeed shorted as tested out of the board.
                      I clearly don't know enough about these types of charging circuits, I never realized the computer could still work even with a shorted mosfet in these HPB designs. I have learned a ton from you.
                      I ordered a CSD17573Q5B as that's what I could find quickly without ordering from China. Hopefully, it will work.
                      Thanks again!
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • coasterghost
                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                        by coasterghost
                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                        System Hardware:
                        Processor: AMD Ryzen 7 PRO 5850U
                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                        09-08-2025, 10:46 PM
                      • flat-earther
                        how to prevent a connected charger from draining battery when not charging?
                        by flat-earther
                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                        So the battery is backfeeding the charger and being drained.
                        How can I prevent...
                        08-07-2025, 01:04 PM
                      • dimis1975
                        Macbook A1466 2014 not charging with macsafe 2 charger
                        by dimis1975
                        I have a macboook air a1466 that stopped charging the battery.
                        BAT PINS: with or without ADAPTER IN
                        1- GND
                        2- GND
                        3- GND
                        4-0V sense pin
                        5-3.42V
                        6-3.42V
                        7- 8.4V
                        8- 8.4V
                        9- 8.4V
                        AC Adapter plugged in: after a lot of of hours some times start charging
                        No BAT Connected- Green to Orange
                        AC Adapter plugged in: BAT Connected- no light
                        The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                        Any ideas what’s wrong please?...
                        08-05-2025, 03:43 AM
                      • pc_okay
                        FX516PR not charging on DC charger (but charging on Type-C)
                        by pc_okay
                        Hello friends,
                        I have this board not charging with charger, working fine on battery and type-C charger.
                        Here what if found: my IC chip miss VCC so i follow the line P_CHG_VCC_30 (0V) to P_CHG_VCC_R_30 (0v) and i get 20V A/D_DOCK_IN.
                        I loose my 20V on the PQ9009, i think it's dead because it's a P-Channel and I get 0V on gate and 20V on source and finally 0V on drain.
                        Am I right?
                        Links for shematics and boardview: https://www.badcaps.net/forum/troubl...aptops-tablets...
                        10-02-2024, 06:16 AM
