macbook pro A1707 board 820-00281-A
  • gaui
    • Nov 2023
    • vosges
    Hello
    I'm trying to repair as best I can my macbook pro which suddenly turned off even though there was nothing plugged in and I wasn't touching it. I noted several voltages or not, I'll indicate them to you below if you have any ideas I am very interested thank you in advance
    PP3V3_SUS ok 3.3V
    PP3V3_S5 ok 3.3V
    PP3V0_G3H ok 3V
    PP5V_PMICLDO ok 5V
    PP3V3_S5 ok 3.3V
    PP1V0_SUS no 0V 57hom
    PP1V8_SUS no 0V
    PP3V3_S0 no 0V
    PP5V_S4 no 0V
    The consumption of the Mac is 0.014A and 20V so the USB chips work
    looking at the diagram I think that I can simply bridge the two pins 1 and 2 because I do not have the second component to solder on my original motherboard after that I do not know the functionality of this component
    Thank you again in advance for your help and for reading me
    ps: sorry again for my bad english
  • gaui
    • Nov 2023
    • vosges
    Macbook pro A1707 board 820-00281-A fails to start
    Hello
    PP3V3_SUS ok 3.3V
    PP3V3_S5 ok 3.3V
    PP3V0_G3H ok 3V
    PP5V_PMICLDO ok 5V
    PP3V3_S5 ok 3.3V
    PP1V8_SUS no 0V
    PP3V3_S0 no 0V
    PP5V_S4 no 0V
    • CG_Dionysos
      MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
      by CG_Dionysos
      I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
      • Model: A1707
      • 15-inch, Mid 2017
      • 3.1 GHz Core i7
      • 16 GB RAM
      • Radeon Pro 560
      • 1 TB SSD
      • Board number: 820-00928-A
      I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
      Thanks in advance!
      Greetings from Germany...
      09-16-2025, 06:43 AM
    • leonemax81
      Macbook a1707 820-00281 Battery no Power
      by leonemax81
      Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
      08-23-2024, 09:24 AM
    • sofles
      Macbook a1707 2017 model 820-00928 GPU issue
      by sofles
      Hello there
      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
      11-21-2024, 05:25 AM
    • jesi
      MacBook Pro 820-00281-A A1707 macbook
      by jesi
      hi all techs
      require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
      adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
      update:
      when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
      08-23-2025, 02:35 PM
    • tommy97
      Apple MacBook A1707 No Audio/Sound
      by tommy97
      I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
      I've also replaced U6300, but the problem persists.
      Here are the current voltage readings:
      • PPV18_S0: 1.8V
      • R6402: 1V
      • R6405: 1V
      • R6403: 1V
      • AUD_SPKRAMP_RESET_L: 1.3V
      • PPBUS: 12.6V
      03-10-2025, 11:22 AM
