Macbook A1466 dies when charger disconnected
  • echothegamer
    • Oct 2023
    • 15
    Hello all,
    Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
    Details:
    Macbook 13' A1466
    Board (820-3209-A)
    Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
    Pictures below of Boardview and schematic...
    I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
    It's an older model and it is very likely that battery has become toast after ten years of charging cycles. From my zillions of hours watching MacBook repair videos, however, I have learned there is a diode that can fail and kill the battery/prevent it from charging. Of course, I have checked it in circuit.
    D6905
    Red Probe on Pin 1 to 3 (.227) voltage drop
    Red Probe on Pin 2 to 3 (.227) voltage drop
    Seems normal
    Reversing probes
    Black probe on Pin 1 to 3 (2.330) voltage drop (Hmmmmm...)
    Black probe on Pin 2 to 3 (OL)
    Seems not normal
    Additionally:
    Red probe on Pin 2 to 1 (2.330) voltage drop (DCIN killing battery?)
    Black probe on Pin 2 to 1 (2.978) voltage drop
    SO I believe this diode to be bad but wanted to ask some other techs before ordering a replacement diode.
    Also, the diode says [Z5 23]. I can find nothing anywhere about the part number or specs of this diode. There was a random forum that said 20v 1 amp Schottky diode but that seems off. Also can't find that anywhere on mouser or digikey.
    If you could kindly:
    1) Advise if I am correct in the diode being "the bad guy."
    2) Provide me the part number for D6905 or equivalent.
    OR
    3)Tell me if I'm a silly goose and should just order the replacement battery and stop making things worse for myself and others.
    Thank you
  • mon2
    • Dec 2019
    • 14732
    Re: Macbook A1466 dies when charger disconnected
    Hi.
    1) connect the battery only. Meter in dc volts mode (20v or higher scale).
    2) black meter probe to ground. Red meter probe to the first pin on the battery connector. The first 3 pins are usually the V+ of the battery. Probe each pin and post the full list.
    3) batteries will often support 500 charge cycles and then derate on capacity. Good idea to purchase another from Amazon for testing. It can be returned if not needed. Check if the charge light goes on when battery is connected.
    Check ppbus_g3h at the fuse of the isl charger ic output with only the battery and then with both battery and adapter.
    Do also carefully check the voltage on each pin to ground of the dual diode at D6950.
    Post all measurements. We can find a replacement if required from Digikey / Mouser / Arrow.
    • echothegamer
      • Oct 2023
      • 15
      Hello, mon2!
      Thank you for the quick response.
      Here are the Readings...
      BAT PINS: W/O ADAPTER IN
      1- GND
      2- GND
      3- GND
      4-0.1mV
      5-20mV
      6-20mV
      7- 0.465V
      8- 0.465V ALL dropped quickly to 155mV
      9- 0.465V
      AC Adapter plugged in:
      No BAT Connected- Green to Orange
      ISL G3H FUSE F7040:
      BAT CONNECTED: 100mV and dropped to 1mv after a minute or so
      BAT CONNECTED W/CHARGER: 7.15V
      D6905 DC ADAP Plugged in:
      Pins
      1- 7.6V and climbing to about 8V in 20 seconds (Same readings on PIN 7-9 of BAT CONNECTOR)
      2- 14.75V
      After all that "charging" BAT voltage climbed to almost 2V and practically discharged a full volt in 1 min
      It seems like the battery is toast. But my question is, why does it seem like that diode is allowing reverse polarity when I tested it in diode mode?
      • ACS-Repair
        • Feb 2021
        • 204
        I had something like this on an A1398 where the computer showed the battery at 71% but not charging. it also would not run on the battery. in my case the battery was faulty. I agree with mon2... it's best to have another battery to compare with.
        • echothegamer
          • Oct 2023
          • 15
          Yeah, I agree.
          I just can't afford parts right now, unfortunately. Still don't know why the diode read as it did. I can only assume it is because it was in circuit. But when charging it seemed fine.
          Hopefully, when I get the new battery, we will be all set and charging will be normal.
          Thanks for all the help!
          • mon2
            • Dec 2019
            • 14732
            To properly rule out the diode. Very carefully flux and remove the part. You must be careful with the hot air as the hot air can kill the lcd panel. Once off the board, test the diode in diode mode again. The part is dirt cheap but shipping is always the killer in North America. You will need tweezers and the proper hot air tool to remove off the board. Or lean on one of the many local cell phone techs that should be in your region.
            • echothegamer
              • Oct 2023
              • 15
              Good idea. I will do that before I install a new battery just to be sure.
              Thank you for the heads-up regarding the LCD panel.
              And yeah shipping costs are silly lol
              • Cbizz
                Help Identifying Diode for Macbook Air a1466 with 820-00165 board
                by Cbizz
                While reviewing the a1466 820-00165 board schematics, I came across a diode that I need to identify. The part in question is labeled D2920 (NSR1020MW2T1G), but my problem is that the schematic has the icon for a Zener Diode, but when I look up the part number, I only get results for a Schottky Diode. I don't have much experience with technical schematics at all and this part just so happens to be missing from the board I am trying to fix so I need to get my hands on the correct replacement part.
                I have attached both the schematic portion in question and a screenshot of the part...
                11-13-2021, 02:11 AM
              • psdavid65
                Macbook Air A1466 820-3437-B Booting Problem
                by psdavid65
                I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                06-20-2024, 12:27 AM
              • bastien
                OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                by bastien
                It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                This is the new database for FlexBV
                it's optimized to work with it
                by using board ID has Default name, give us the opportunity,
                to use other diode board data with sibling board or family board
                I Merged the whole data (optimal)
                A2991 A2992 M3 -> -> 2 Entries diode data M1
                A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                A2442 A2485 A2779...
                03-18-2025, 08:03 AM
              • dbuergi
                Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                by dbuergi
                i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                Any ideas where to look?...
                11-07-2024, 10:57 AM
              • Sergio Kub
                MAcbook Air A1466 EMC 3178 - 2017 Boot
                by Sergio Kub
                Could someone help me?
                I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
                Could it be the BIOS?
                07-08-2025, 04:41 PM
