HP Envy 17tbw000 not detecting battery.
  • redbaron1007
    • Jun 2021
    • 117
    Hi all, I've got an HP Envy 17tbw000 with a haymitch 2g mb 17888-1 motherboard that isn't detecting batteries. I've tried two different batteries and it doesn't detect either of them. I have a donor board with a dead CPU I've been pulling parts off of. I replaced the BQ25708 IC as well as two 10.5 ohm connected to pins 19 and 20 that were reading ~100-200 ohms and had physical damage on the top of the package. I also tried replacing the fets on the battery charge circuit because I had spares and all of this hasn't changed anything. I don't have a schematic so I can't find the 10kohm resistors that the datasheet for the BQ IC says should be present on the smbus pins 12 and 13. I have already read through https://www.badcaps.net/forum/showthread.php?t=90356 and is how I got into looking at the smbus and trying to find those resistors.
    I have also tried reflashing the bios and have had no success with that either. The laptop will turn on when the charger is plugged in, but shows the battery as unidentified. With the new battery it will stay on for a few minutes when the charger is unplugged. When I check the battery voltage when the laptop is not plugged in I get 0V across all pins, but when the charger is plugged in I get 9.04V on + and 3.05V-3.07V on /,D,and C pins and 0V on gnd.
    I have had no luck finding any schematics or any other information about this fault other than others asking for the schematic.
    I forgot to bring the pictures of the board I took with markups on them home with me when I left work today, but I can upload those tomorrow if it would help anyone.
  • mon2
    • 14666
    Re: HP Envy 17tbw000 not detecting battery.
    Locate the vcc power pin for the bq charger ic. There should be a 3 pin dual diode nearby. This diode powers the charger ic. Check that there is power for all cases.
    Adapter only.
    Battery only.
    Adapter and battery together.
    The higher of the 2 power sources will power the charger ic.
    Confirm the above.
    • redbaron1007
      • Jun 2021
      • 117
      I checked the voltages and get following on pin 1 VBUS
      Adapter only 19v
      battery only 0v
      Adapter and battery 19v
      I don't get any voltage coming from the battery when the adapter isn't plugged in. When I disconnect the charger The voltage on the battery goes from 10v down to about 2v and then back to 0v. I have access to the tabs coming off the battery to the control board and I do have ~2.9v-3v on each of the three cells in the battery. All three cells are within .005v of one another. The cells were reading higher yesterday when I was working on the laptop ~3.5v. If I leave it on the charger for a few hours the voltage goes back up and the laptop does seem to be charging the battery.
      • mon2
        • 14666
        Are the batteries you have tested known good ones and compatible with the motherboard? It is possible that the bms is locked out.
        Suggest for you to source another battery pack from Amazon which is risk free and test again. You can keep or return the battery pack if it is not required.
        Be sure the battery pack smbus lines are reaching the charger ic. Confirm it with a meter in resistance mode with no power to the board. Remove the battery and check the resistance from the battery connector contacts to the charger ic.
        • redbaron1007
          • Jun 2021
          • 117
          One of the batteries is the one that was the original one from the laptop that the owner replaced with one they bought from HP. The other one is the one they bought from HP directly that was also having the same problem.
          I ended up buying a replacement battery for cheap off amazon to test with and rule out the batteries, but it's still got the no battery detected issue.
          I checked the smbus lines and was getting ~2 kohm on one of the lines and ~4 kohm on the other. I don't remember which one was which.I wrote it down, but left my notes at work. From reading the datasheet for the bq chip there's supposed to be a 10 kohm resistor somewhere between the IC and the smbus pins on the battery connector so I was expecting higher resistance values. I couldn't tell from the datasheet if the 10 kohm was a requirement or a suggestion.
            NVDC charger configuration...
            11-05-2024, 03:28 PM
            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
            Narrow VDC applications where the system power source is
            either the battery pack or the regulated output of the charger.
            This makes the max voltage to the system equal to the max
            battery voltage instead of the max adapter voltage. Operating
            at lower system voltage can improve...
            11-05-2024, 04:43 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
            Bauer tool battery pack charging with a HERCULES charger modification
            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
            05-06-2023, 12:17 PM
