Hp Go14 not booting into windows
+ More Options
Posts
  • Herbssat
    • Sep 2011
    • 194
    Hey guys. Currently working on a 24inch all in one computer that will not boot into windows neither safe mode. Pressing f11 does get you into the troubleshooting mode where you can reset the pc etc…. System restore said there was some corruption so a chkdsk was performed but after the restore was initiated nothing changed. The computer shows the hp logo, then goes to a small spinning circle ending with a blank screen. I am inclined to believe that this is some kind of graphics problem possibly but wanted to see if anyone can give some idea on what to check. Maybe the problem is not worth fixing idk. Thanks for any help.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hp Go14 not booting into windows
    See if it will boot a version of Linux off a USB stick or replace the SSD/HDD and try reinstalling Windows.
    • Herbssat
      • Sep 2011
      • 194
      Thanks for the response diif. I had already torn down the computer so i stuck another drive in and programmed windows. Seems to be working fine. Now i need to check the other drive further to see if the corruption can be reversed. Crystal disk mark says the drive health is good . Another user in the hp forum experienced the same problem with this unit and it ended up being a graphics problem. Followed the same procedure by replacing drive etc.... Worked good for a while and computer started to pixelate etc....
