LA-K862P UMA conversion
  • orientalsniper
    • Apr 2013
    • 461
    Hello guys, I got this LA-K862P motherboard, it has a shorted GPU core and memory chips, I've already desoldered the memory chips, do I need to desolder the GPU for an UMA conversion?
    I've done the following:
    • Moved RH44 resistor to RH43 (uma resistor switch)
    • Removed PLW1 and PLW2 (gpu power)
    • Removed PLV2, PLV3, PLV4, PLV13
    I'm supposed to have 19v in PLB1 (+19V_CHG) but there's a leakage and I'm getting ~3v.
    Schematic and BV here: https://www.badcaps.net/forum/showpo...79&postcount=2
  • tony stark
    • Aug 2017
    • 36
    • india
    Re: LA-K862P UMA conversion
    Originally posted by orientalsniper
    hello guys, i got this la-k862p motherboard, it has a shorted gpu core and memory chips, i've already desoldered the memory chips, do i need to desolder the gpu for an uma conversion?
    • moved rh44 resistor to rh43 (uma resistor switch)
    • removed plw1 and plw2 (gpu power)
    • removed plv2, plv3, plv4, plv13
    i'm supposed to have 19v in plb1 (+19v_chg) but there's a leakage and i'm getting ~3v.
    Schematic and bv here: https://www.badcaps.net/forum/showpo...79&postcount=2
    remove prv74 only
    • orientalsniper
      • Apr 2013
      • 461
      Conversion was successful by removing PRV74 and GPU, I'm not sure which one helped.
