MacBook pro A2289 with touchbar stuck at 5V, 0.43A
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Greetings everyone.
    I've been trying to resolve the above problem, I need insight into the next step to take. This will be my first time handling this kind of machine hence, any replacement part will need to be ordered for since I do not have replacement parts.
    readings on the MB:
    PPBUS_G3H is present (12.23v)
    PP3V3_G3H is present (3.27v)
    PP1V8_SLPS2R is present (1.7v)
    The C-ports behavior:
    The port that communicated with U3200 delivered the above readings although the u3900, u3100, u3200 regions warmed up.
    However, the port that communicated with the u3100 delivered different readings- PPBUS was 1.7V, PP3V3 is 0. but the voltage at the USB meter still reads 5V, 0.43A
    I found out PP3V3_UPC_XA_LDO on U3100 read 26ohms to ground, it remains the same after I removed C3108. While PP3V3_UPC_XB_LDO on U3200 read 1.3k to ground. But the voltage reading at u3200 is 3.3V while at u3100 is 2.3V
    I'm stuck at which step to take next:
    Do I replace the U2890 or U3100 or attempt DFU mode so as to reprogram the T2 security chip, or should I remove the U4770 and reprogram it?
    I have a EZP2019 programmer, I think it should be able to read and write on the U4770 chip, but I couldn't lay my hands on the firmware yet.
    Please, what would you advise?
    background information on the PC:
    The charger was shaky, it indicated charging not charging, an attempt was made to adjust the charger perhaps it would stabilize, but a sparking sound was heard. the PC was unplugged, but the charging notification was still on despite the fact that the PC had been unplugged.
    Owner said the battery was not charging at all, it decreases even when the PC is plugged in, but the notification says the PC was charging. He attempted PRAM/SMC reset but the PC died afterward
  • mon2
    • 14366
    Re: MacBook pro A2289 with touchbar stuck at 5V, 0.43A
    Is the current draw from the type C port static at 0.43A or a variable and peaks to this value?
    The ISL device is a buck-boost regulator.
    The default power delivery contract is 5V. With this voltage as an input, the ISL will act as a boost regulator to output the ppbus_g3h rail.
    When the cd3217 devices are working correctly, the power delivery will bump to 20v as the input. Then the ISL will enter buck regulator mode to offer a lower output voltage with the higher input voltage.
    The difference being that in boost mode, the regulator current is always lower than when in buck regulator mode.
    The low resistance on the LDO rail is of concern.
    • Zilicon
      • Nov 2020
      • 142
      • Nigeria
      Yes, it is constant.
      the port that doesn't produce PPBUS reads: 5V 0.17A
      while the PPBUS is 0.7v
      the PPBUS of the working port is 12.18v
      • mon2
        • 14366
        SMC has not kicked in to boost this to 12v6.
        Reference:
        https://logi.wiki/index.php?title=PPBus_G3H
        Is the power delivery type C meter reporting 5v or 20v from the external power adapter? It must be 20v if all is working properly with the CD3217 controllers.
        Review each of the LDO rail on this non-working port.
        Review the DIODE mode readings of the CCx lines which are used for the BMC communication with the external power delivery adapter. CC1 will be used on one side of the type C blade / CC2 on the other side.
        Remove all power -> meter in diode mode -> red meter probe to GROUND (yes red) -> black meter probe onto CCx pin to test. Compare these readings against the working / known good port(s).
        You may have to replace the CD3217 controller if it is not working.
        • Zilicon
          • Nov 2020
          • 142
          • Nigeria
          Reference:
          The type c meter reported 5v, 0.43A
          • Zilicon
            • Nov 2020
            • 142
            • Nigeria
            Reference:
            The CCs read fine.
            XA_CC1 0.537
            CC2 0.534
            XB_CC1 0.539
            CC2 0.538
            I might have to replace U3100, especially since both C ports behave differently. wish me success
            • mon2
              • 14366
              Review this:
              https://boards.rossmanngroup.com/thr...k-at-5v.63201/
              • Zilicon
                • Nov 2020
                • 142
                • Nigeria
                Alright.
                Thanks a lot, Mon2, I really appreciate your invaluable assistance
                • abajor
                  A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                  by abajor
                  Like title says A2141 came in with Water Damage, customer desperately wants the data.
                  The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                  I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                  That said after cleaning up the...
                  12-21-2024, 07:16 PM
                • abajor
                  MBP A2289 board 820-01987 Bad U3200?
                  by abajor
                  Just looking for a second opinions before I try to source a CD3217
                  Rear USBC sits at 5.1V 0.01A
                  Forward USBC power cycles.
                  PPBUS_G3H 7.5-8.3V cycles with rear USB, Cycles 0-12.5V on forward USBC
                  PP3v3_G3H_RTC ~3.9V with rear USBC, cycles 0-5.1 on forward USBC.
                  PP3v3_UPC_XB_LDO diode drop reads about 0.074V
                  I'm almost positive it's U3200 (its also the only thing getting warm on thermal camera) second opinions always helpful.
                  Thanks!
                  05-10-2025, 03:08 AM
                • Dallas90
                  A2289 MacBook Pro - No power - Need help!
                  by Dallas90
                  I need your help with repairing this Macbook Pro. The fault is that the laptop does not power on. there are different current draw from the various USB ports.
                  It is worth mentioning that there is no liquid on the board after a visual inspection. below you can see all readings and info after some diagnostic.
                  There are also some thermal images uploaded in the thread.
                  What should I do next? any suggestions?
                  Thanks in advance.
                  Current draw:
                  USB port 1: 4.9V - 0.356A
                  USB port 2: 4.9V - 0.056-0.60A...
                  02-01-2024, 04:41 PM
                • francescoranchi
                  MBP 13inch 2018 No Power - 820-00850-07 motherboard faulty (U3100 get's hot)
                  by francescoranchi
                  Hello everyone! I'm new to this forum but I hope I can find help and also help others at the same time!
                  I have a MacBook Pro 13inch from 2018 and it doesn't turn on anymore it's completely gone. I was using it connected to a USB-C / HDMI adapter to connect it to the tv when it just turned off and it's not powering on anymore.
                  I don't have an AMP meter so I can't see how many amps are getting pulled. The only symptom is the U3100 getting very hot, upon closer inspection it looks like it burned because there's a small hole on the top surface of the IC (I've already seen...
                  09-16-2023, 07:08 AM
                • Jamo33lovelock
                  820-01814-A Touchbar not functioning
                  by Jamo33lovelock
                  This is my first post asking for help, but I feel I have now reached a point where I am out of my depth entirely.
                  820-01814-A board model, purchased with knowledge it was faulty and had water damage that had affected the touchbar. Water damage was located around the touchbar connectors to the point there were open circuits. When turned on the touchbar would light up, but the entirety of it was scrambled colours and pixelation.
                  I replaced the topcase (wasn't comfortable doing a touchbar swap) expecting this to be a simple issue of an open circuit, but...
                  09-06-2022, 04:12 PM
