HP Omen 16 no display
  • fhulgzz
    FotoCloudz
    • Sep 2020
    • 15
    • Philippines
    Hi I need help, I hope someone can help me.
    Model: Omen 16 B0080TX
    Board Code: DA0G3KMBCG0 REV:G
    I have a hard time diagnosing because there is no schematics/boardview available yet, if you have, please share.
    ISSUE
    • My personal laptop I used for my repairs. While in sleep mode it wont turn back on so I long press power button to turn "off" then press again to turn "on" and there the screen is black, no display
    • Charger is working
    • It has power, keyboard lights is on but CAPS LOCK light is not, looks like its freezing.
    ACTION TAKEN
    • replace good ram
    • connected to external monitor HDMI
    • remove everything connected to motherboard and tried, still no display.
    • flash bios with clean ME and other working dump bios still no success.
    This is the picture of the motherboard
    Question 1: Please help me locate the RTC circuit, can't find it cause there is no schematics.
    This are the voltage measurements when power is on. Looks normal to me.
    This coil near the SPI chip and wifi slot has unusual heat / overheating maybe, but there is no short on the caps around. I was thinking maybe this circuit is faulty.
    This is the IC near the coil that has unusual temperature or has overheating. The IC itself is overheating.
    Question 2: Please help me identify this IC, so that I can try and replace it maybe this one is faulty.
    Question 3: Is it safe to remove this IC and power it on? I'm asking because last time I remove some IC (on different motherboard) the component near it got burnt.
  • mon2
    • Dec 2019
    • 14631
    Re: HP Omen 16 no display
    Part is from Alpha Omega Semiconductor.
    See attached.
    • fhulgzz
      FotoCloudz
      • Sep 2020
      • 15
      • Philippines
      See attached.
      thanks Sir, could this be a good replacement? I'm not sure yet because there is no schematics of the board but looking at the physical pins, they look the same. I will check the pin configuration manually if they are the same.
      • natic
        • Sep 2018
        • 34
        • EU
        Hello!
        The RTC quartz oscillator (32.768kHz) is most likely the one marked in the following picture.
        Yes, it's safe to run the machine without this chip.
        - Measure the resistances to ground on all coils.
        • Sephir0th
          • Oct 2020
          • 1283
          Exactly, resistance measurements please. A warm 1.8V supply isn't a good sign but normally has nothing to do with the buck converter, but with the load.
          Actually I don't understand the point to let the board run without 1.8V supply. There will be nothing to achieve. The board can not perform P.O.S.T. this way. Same with the RTC circuit. There is likely no issue if the board reaches S3 or even S0 state.
          Measurement of the CPU and the GPU are missing completely instead and need to be added for a whole overview about then situation.
          FairRepair on YouTube
          • fhulgzz
            FotoCloudz
            • Sep 2020
            • 15
            • Philippines
            Hi, here is the resistances to ground on all coils.
            • fhulgzz
              FotoCloudz
              • Sep 2020
              • 15
              • Philippines
              Hi, I already measure the resistance to ground posted above this comment.
              Im sorry maybe we have different understanding or terms on what is a "load" means. Maybe load has different meaning in my language . Can you point me to the right direction where is the load your are referring to or what pin in this buck converter?
              I ask if it is safe to run the board without this IC because it is only my wild imagination to further test the voltages around this circuit, its hard without schematics to follow.
              Hope you have time to help me with this.
              • mon2
                • Dec 2019
                • 14631
                The load will be the cluster or group of parts that are being powered by the power rail that follows after the inductor or LDO regulator output.
                A LDO regulator for example, effectively burns off the higher voltage from the input side to offer.a lower output voltage. This process will cause the LDO to generate heat.
                An inductor will imply the rail is a switch type design and will pulse on/off to create the lower output voltage but will be more efficient than the LDO and will generate less heat.
                Either way, if the load is excessive, expect more heat.
                • fhulgzz
                  FotoCloudz
                  • Sep 2020
                  • 15
                  • Philippines
                  Great, thanks Sir for the explanation.
                  So I will focus on the load maybe there is problem there.
                  If this is a 1.8v pch power ic, is it possible the pch is faulty?
                  Or anything somewhere after the inductor?
                  I will check this and post update.
                  • sikocan
                    • Oct 2019
                    • 344
                    Great explanation!
                    Regarding the OHM measurements you've taken, please take them once more. Set your multimeter to the 200 range. Any reading above 200 ohms should display as OL. For anything below that, share the readings rounded to two decimal places. For instance, the GPU might show as 0.23. Also, measure the resistance of your cable by connecting to two ground points on the board and share that reading too.
                    • fhulgzz
                      FotoCloudz
                      • Sep 2020
                      • 15
                      • Philippines
                      Originally posted by sikocan
                      Great explanation!
                      Hi here is the measurement at 200 ohms range on multimeter.
                      Ground to ground resistance is 2.2 ohms.
                      • fhulgzz
                        FotoCloudz
                        • Sep 2020
                        • 15
                        • Philippines
                        Up for this.
                        • fhulgzz
                          FotoCloudz
                          • Sep 2020
                          • 15
                          • Philippines
                          Sir do you have any further ideas? Im stock here without schematics. I badly need help. Thanks in advance.
                          • Sephir0th
                            • Oct 2020
                            • 1283
                            This looks all fine to me. Since even the RAM supply is up and running it's the time to take a look to the coils above the CPU and GPU. We need to know the present voltages there.
                            • fhulgzz
                              FotoCloudz
                              • Sep 2020
                              • 15
                              • Philippines
                              Hi, here is the voltage measurement of the coils near the CPU and GPU. Kindly check. Thank you
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                The voltage readings look good. Btw, DRAMRST# present on pin108 of ram slot?
                                • fhulgzz
                                  FotoCloudz
                                  • Sep 2020
                                  • 15
                                  • Philippines
                                  Yes, pin108 on ram slot has 1.2v
                                  • Solennia
                                    • Nov 2023
                                    • Pakistan
                                    Hey, did you manage to solve the issue? I am having a similar problem with my machine. Its an hp omen 16 as well with blackout display and bios chip overheating problem.
                                    • fhulgzz
                                      FotoCloudz
                                      • Sep 2020
                                      • 15
                                      • Philippines
                                      Not yet. Still waiting for some inputs by the other members here. Its hard diagnosing without schematics. I dont want to guess and cause more damage to the motherboard. Hope someone can give thier expertise.
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Consumption on dc supply
                                        01 With Ram
                                        02 Without ram
