HP 840 G1 battery and charging issues
  • flc1988
    • Nov 2018
    • 11
    • BRAZIL
    HP 840 g1 - new battery - when inserted, it turns on normally from the battery and when inserting the charger it starts to use energy from the charger. The battery is not recognized (%), but when removing the charger the notebook continues to use battery power. The laptop does not charge the battery.
    there is a message: "warning - machine is not commit state"
  • mon2
    • 14662
    Re: HP 840 G1 battery and charging issues
    Since the battery is not recognized, do check that the contacts are mating with the battery connector on the logic board and with a good seating.
    Meter in voltage mode. Carefully measure the voltage to ground on each pin of the battery connector. Checking the voltage to ground of the smbus lines (SCL and SDA) which are used by the host logic board for the battery details. If either of these 2 lines are parked (ie. Damaged from ESD event) then the communication will halt. The other possibility is that the battery is defective for the bms inside the battery pack. Would you have the older battery still? If yes, does it get detected by the logic board?
    • flc1988
      • Nov 2018
      • 11
      • BRAZIL
      Two batteries were bought, the first one didn't know and the customer returned it. The second was also not recognized. I quickly checked the pins and they are clean. On Wednesday the client will bring it to me again. The charger is HP original 90w.
      • mon2
        • 14662
        The smbus lines voltage readings are a suspect. They must be ~3v3 for each.
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • DaLZy
          Extremely Strange Issues with charging and battery on Zephyrus G14(GA401)
          by DaLZy
          I have recently come into possession of a G14 that cannot detect or charge it's battery. Initially both windows and the bios agreed that the battery was on "0%" but the laptop was able to run without AC power. I was able to get the laptop to detect the true charge of the battery(26%) in windows for a moment but it wouldn't charge or update the percentage when the battery drained. I attempted a few more EC resets and battery reconnections and now the battery shows at 0% in bios and 100% in windows. Additionally the machine is extremely laggy when plugged into AC. When on ac power in the...
          01-27-2025, 12:38 AM
