hp 450 g8 not turn on(DAX8QMB28A0 REV:A)
  • arber1232
    • 378
    • Albania
    Hi everyone !!!
    I have a Hp 450 g8 in the service which does not turn on. There is no light when I put the charger, I tried several chargers such as blue head and type-c but again no light.
    I have 19v in the mosfet and 3.3v in the power button. In the legs of the bios I have 0.1v and in the nuvoton ic I have 0.1v, so I still don't have a schematic for this laptop. I have checked all the coils in ohms but do not have shorts
    can i help me ?
  • mon2
    • 14659
    Re: hp 450 g8 not turn on(DAX8QMB28A0 REV:A)
    Which charger IC is onboard? Review the usual DCin mosfets and the charger IC should be nearby.
    • arber1232
      • 378
      • Albania
      Bq24780s
      • arber1232
        • 378
        • Albania
        Acn=0v
        acp=19.5v
        csmrc=19.5v
        acdrv-25v
        acok-0.1v
        acdet-3,3v
        adp-0v
        VCC=18.9V
        LODRV=0V
        REGN=6V
        • mon2
          • 14659
          ACP is ok but ACN is not. Double check the voltage to ground of ACN.
          There will be a current sense resistor of a few milli-ohm between ACN and ACP so it does not make sense that one side will have 19v but the other side will be 0 volts. At least on a known good board, both legs should be ~19v.
          Also, remove all power, meter in resistance mode. Check the resistance to ground of ACN.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            ACN/ACOK/ACDET-all are wrong. Re check your measurements.
            • nikolayu
              Dell Latitude 5420 wont turn on when charger is connected
              by nikolayu
              I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
              Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
              The same thing if I connect to other USB C port.
              Charger is OEM
              03-13-2024, 12:34 PM
            • vdrokko99
              MBP wont turn on Only green light on charger
              by vdrokko99
              I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
              SMBUS_SMC_BSA_SCL 3.5V
              SMBUS_SMC_BSA_SDA 3.5V
              12-01-2024, 12:18 PM
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
