Water damage MBP 15 2018
  • David82827372
    • Aug 2023
    • 10
    • Kyrgyzstan
    Can you assist in identifying the issue and providing repair steps?
    There are no official Apple service centers nearby, and the authorized centers don't have best reputation. To avoid potential further damage from these "experts," I'm interested in obtaining guidance from those who have already resolved a similar problem.
    Water entered the connection between the screen and keyboard of my MacBook Pro. The power button has stopped functioning. I have to use the charger to turn on the MacBook.
    Furthermore, even when connected to the charger, it's challenging to turn it on, as after about a hundred attempts, the MacBook starts charging from one of the ports and only then powers up. I've changed outlets and cords, yet it seems like the MacBook randomly chooses when to recognize the charging.
    After several hours of inactivity, the MacBook cannot be quickly turned on by opening the lid. Instead of a swift startup, the Apple logo appears, and the boot-up process is akin to turning on the MacBook after a prolonged power button press.
    Additionally, in the battery settings, a message "service required" has appeared.
    MacBook Pro 2018 15" A1990
  • kew1701
    • Nov 2013
    • 40
    • Poland
    Re: Water damage MBP 15 2018
    Follow some tutorial how to open this model,take some brush and IPA,and all your problems with mbp will be gone.You can spit in hands if this will gonna bring U luck...happy cleaning
    • Ugur87
      MacBook Air M4 A3240 Brand New Water Damage no Image
      by Ugur87
      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
      08-28-2025, 01:09 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • TimSinger
      MacBook Pro M4 16" A3403 on the table with water damage
      by TimSinger
      Hi guys,
      I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
      I attached a photo of the missing cap. It's on the bottom side of the logicbard.
      I am very thankful for your replys.
      Thanks in advanced and best regards from Hamburg Germany...
      07-13-2025, 11:12 AM
    • dbuergi
      Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
      by dbuergi
      i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
      Any ideas where to look?...
      11-07-2024, 10:57 AM
    • Grandoni Manuel
      MacBook a2289 water damage
      by Grandoni Manuel
      Hello to all ! I follow you but this is first time write !!
      your forum is the best !!
      so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
      now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
      q8400
      q8401
      D8410
      and the resistor R8431
      if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
      on...
      04-03-2025, 06:45 PM
