820-00840 stuck at 5v on port a, 5v loop on port b
  • phantomEVO
    • Mar 2013
    • 509
    Hi guys i have an 820-00840 that not boot... (stuck at 5v)
    here there is the history of previous techician (i can't say if it is 100% true)
    macbook dead
    found a short with thermal camera on c3000
    caps removed (not replaced)
    tried to charge -> smoke
    found u3100 burnt
    changed, no luck
    changed u3200 no luck
    rechanged u3200 with the original one. No luck
    now i have this laptop.
    i have discovered that i have 5v @0.20a STUCK on usb port connected on 3100
    i have 5v@0.40a in bootloop on usb connected on 3200...
    any help?
    Here ppdcin g3h chgr behaviour (if i connect power supply on the port that loops)
    No voltage it i connect in the other port
  • phantomEVO
    • Mar 2013
    • 509
    Re: 820-00840 stuck at 5v on port a, 5v loop on port b
    Update: changed but usb-controller
    Now i have 20v stuck at 0,13amp
    Using Thermal camera i have u7800 super hot and one usb-c controller hot
    https://uploadnow.io/files/5Ppwgwk
    I have checked for shorts around and under u7800 with no luck
    I have pp3v3 ldo 3v
    I have ppbus pmic 13v
    I have pp1v25_ref 1,3v
    But pp5v ldo stuck at 2,7v This Line is not shorted
      • 21874
      Post your images to badcaps as an attachment please, the link goes to a login screen,it might be working ok for you but nobody else can see anything.
      • phantomEVO
        • Mar 2013
        • 509
        It is a video!
        Can’t you see it?
        https://youtube.com/shorts/Y6c0LVh7DPw?feature=share
        • phantomEVO
          • Mar 2013
          • 509
          Check Now
          https://uploadnow.io/s/46288f1b-0bf1...0-eeb33a19aa0d
          • phantomEVO
            • Mar 2013
            • 509
            Ok i have replaced u7800 Now i have po5vldo… u7800 is not super hot anymore…(but hot together with u7100)
            Now is super hot u3900 and a little bit cpu…
            This is the amp meter
            https://uploadnow.io/f/nJDYmsx
            I have Nothing on display, no caps lock no fan spinning
            • phantomEVO
              • Mar 2013
              • 509
              Changed u3900 still the same…
              Please help!
              • mon2
                • 14662
                Try to test with a bootable USB media and check if the LED on the memory stick blinks during the boot process or not.
                Could be a defective CPU but the climbing current draw in your posted video may show some hope that the logic board is booting.
                https://boards.rossmanngroup.com/thr...no-post.50188/
                • phantomEVO
                  • Mar 2013
                  • 509
                  But i have not fan spinning or sound, i have not video and a chip super hot…😕
                  • mon2
                    • 14662
                    U3900 is linked to the camera assembly.
                    Disconnect the camera cable and attempt to boot up again.
                    • GlenBrim
                      1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                      by GlenBrim
                      I got this recently as-is. Gigabyte 1070 video card.
                      DVI port is removed. I don't know why.
                      A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                      I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                      The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                      02-14-2024, 02:08 AM
                    • Daniel Larsson
                      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                      by Daniel Larsson
                      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                      During these seconds the function button is not working...
                      08-13-2025, 10:29 AM
                    • Mschrenkz@gmail.com
                      Hisense 60R6E - No backlight - stuck in boot loop
                      by Mschrenkz@gmail.com
                      I joined hoping I'll be able to verify which component I need to replace on my Hisense 60R6E. When I plug it in the red light comes on and stays on for several seconds then blinks off and then on again. There is no back light but I can see the logo screen "Hisense Roku" (using the flashlight method) come on while the red light is off. Then it dissapears and the red light is constant again. This cycle keeps repeating. I tried pressing the reset button and it has absolutely no impact. Even held it in for 30 seconds also tried holding the power button in with the TV unplugged - nothing...
                      05-09-2023, 08:53 AM
                    • Stunt
                      Hp Laptop Stuck on Hp protected by hp sure start screen
                      by Stunt
                      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                      screen that's it and stuck there. I left it until the following day and i still...
                      09-02-2025, 01:51 PM
                    • Takeatry
                      Yet another Samsung QLED Boot Loop
                      by Takeatry
                      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                      10-04-2024, 02:57 PM
