ipad pro 4th 12.9 no power after wet
  • khj
    • Jun 2023
    • 14
    • korea
    My ipad pro 4th 12.9 is no power after wet.
    What is mainstream problem?
    I input power using my power supply but it looks 0A.
    I think there is some short so it cant charging and turning on.
    But i cant find shorted cap. They show 3.5V. What should i do in this case.
    There is who has board view?
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: ipad pro 4th 12.9 no power after wet
    Schematic sub-section is here:
    https://www.badcaps.net/forum/forumdisplay.php?f=41
    Use the search engine to find what you are looking for, if you can't find it, open a new request.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • proxneo
      iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
      by proxneo
      Dear reader
      TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
      I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
      12-01-2023, 04:14 AM
    • grimacelord
      Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
      by grimacelord
      Hello.
      Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
      If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
      For example, when I connect the iPad to...
      04-15-2022, 11:06 AM
      09-06-2024, 05:59 AM
    • Gentian
      Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
      by Gentian
      I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
      09-27-2025, 11:03 PM
    • SolderNewbie
      IPAD 6 (2018) A1893 No power
      by SolderNewbie
      I'm trying to fix an IPAD 6, 2018, A1893 WIFI.
      It does not turn on and does not enter recovery or dfu mode.
      History
      The device was working before, but did intermittently reset.
      I gathered two panic logs:
      "panicString" : "Attempting to forcibly halt cpu 0\ncpu 0 failed to halt with error -5: halt not supported for this configuration
      "panicString" : "panic(cpu 0 caller 0xfffffff020e14724): nvme: "AppleEmbeddedNVMeController. Controller fatal bit set. Write.
      I attempted an IOS update to the newest...
      12-21-2024, 03:50 AM
