Replace tpm chip in dell xps 9560
  • jbomba
    • Feb 2012
    • australia
    Hey guys , I have tried everything to get the tpm chip recognised in bios to no avail. I was wondering if anyone had any success replacing the Tpm ic in these laptops? I have located the ic and it seems like a straight forward swap. Just wondering if the ic needs to be programmed? I was looking to do a swap from a similar model with the same nuvoton NPC650Tvb2yx. Wondering if anyone has had any success?
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • ed1i
    Dell Inspion 7610 bios chip
    by ed1i
    Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
    01-16-2025, 02:14 PM
  • donnietr
    Need help id'ing chip on a Dell g15 5515
    by donnietr
    Hello all,
    I have this dell g15 Ryzen Edition 5515. Board GDL56 LA-K453p. It had liquid damage when i bought it. Cleaned it up really well and then used thermal camera to see what got hot.
    Found the power pdw1 and pdw2 under the graphics card were getting hot. Pdw2 was hottest, i had a similiar chip on another board so i put it on this board.
    The other chip is now hot as well, which it was to begin with.
    Thats the problem as i dont know what to call it, like is it a mosfat? or what?
    I will attach a picture of both the boardlabel and of the area with the chips....
    07-18-2025, 08:03 PM
  • ezenia
    Dell G3 3579 BIOS chip ID
    by ezenia
    I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
    06-16-2025, 08:07 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
