Smd chip identification marked L5B .MESC5V02BD03_SOT23-3
  • mentofenol
    • May 2021
    • 6
    • Portugal
    Hello!
    I have an Acer motherboard with a chip i can not find equivalent, its a MESC5V02BD03_SOT23-3 which has inscrit on it L5B.
    Could somenone help me find a compatible or equivalent one?
    Which kind of component might be this?
    Thank you in advance.
  • mon2
    • Dec 2019
    • 14677
    Re: Smd chip identification
    This is a common jellybean part. This is a bidirectional dual ESD diode to protect 5 volt signal lines in a sot23 package. It can be replaced by many others.
    From where do you like to purchase your parts?
    Was this part near your USB connector?
    Correction: the MESC5V02BD03_SOT23-3 is a unidirectional dual ESD diode. That is, the part will only allow for positive voltage to pass through and will immediately block negative voltage. If the line goes above 5 volts in the positive side, this diode will shunt the voltage to ground. Summary: dual lines will be protected from transient surges beyond 5 volts. The electronic symbol (bidirectional) shown in your post is not matching this part which should be unidirectional.
    • mon2
      • Dec 2019
      • 14677
      https://www.digikey.ca/en/products/d...RoC8xMQAvD_BwE
      https://canada.newark.com/bourns/cds...oss_price=true
      • mentofenol
        • May 2021
        • 6
        • Portugal
        Hi mon2,
        first of all thank you for your precious help and explanation. In fact this part is near the RJ45 lan connector. (i attach a piture of it on the red square)
        I have some other faulty laptop boards, which i can try to find those equivalent parts you mentioned, maybe i can find something.
        Meanwhile i found the memory slot and KB9052Q-D chip have some pins with corrosion, thats a diferent level of repair i might try to do, dont know if with sucess.
        The pins on motherboard seem they are compromised, if so, thats maybe the end of it
        Thank you, appreciate very much your help.
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • e-repair
          Chip identification on hp omen 17cb1008tx
          by e-repair
          Hello !
          i have an to repair an hp omen 17cb1008tx.
          i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
          can you help me find a reference for this ic ?...
          09-23-2025, 03:38 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Sunday1302
          Need help with GIGABYTE B550 UD AC REV 1.0 chip identification
          by Sunday1302
          I removed this chip with markings "14 8A SA4" between an HDMI port and a USB port that was faulty. I need to replace it, but I have not been able to properly identify this chip using the markings provided on the chip itself. If anyone is able to provide information regarding this chip, I would greatly appreciate it....
          10-26-2025, 02:35 PM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
