HP Envy 17-ce009nf laptop that won't start
  • Christian0734
    • Nov 2020
    • 92
    • France
    Re: HP Envy 17-ce009nf laptop that won't start
    Originally posted by mon2
    What are the top side markings of PU4401 ic in this last picture? This is the square ic with pins on each side and close to the memory socket.
    It's an 'Intersil 9538BH' battery management chip. The first thing I need to do is to fix my big mistake before addressing the initial problem! I've ordered the 3.2v/5v chip that is overheating, but it's not guaranteed that something else isn't causing the fault.
    • Christian0734
      • Nov 2020
      • 92
      • France
      I believe it is essential to find the schematic or the boardview of this motherboard. I can't even locate the main power lines. I observe that after removing the 3.2v/5v chip, which was heating up a lot, now there are two mosfets that heat alternately. That is, when I send current to the power connector, it's the one on the right that heats up first, and then possibly the one on the left. I'm a bit lost...
        • 21889
        Beginner's guidelines -> https://www.badcaps.net/forum/showthread.php?t=88758
        2. What not to do
        2.7. Don't apply power to the board with missing components
        As a general rule, if a component is on the board, it's because it's useful for something. Engineers don't like adding a bunch of useless components on the board, it's harder to draw the schematics and route on the PCB.
        Some of them can be removed without creating problem if power is applied, but others can kill the board with no possibility of repair.
        For example, if you remove a buck controller or a MOSFET driver, the MOSFET gates will be floating. They'll charge up enough so that the MOSFET turns on. Of course, you don't want the 19V from the main power rail to go straight through the CPU VCore MOSFET to the CPU.
        • Christian0734
          • Nov 2020
          • 92
          • France
          I understand your message well. I still wanted to know if it was the 3.2v/5v chip that was short-circuited, but thank you for your warning.
          • Sephir0th
            • Oct 2020
            • 1289
            No, you have not understood. "First do, then think" is the opposite of systematic troubleshooting.
            Meanwhile you made the issue worse two times in a row. The first time by injecting 13Volts into what I assume is a 5Volts rail and the seconds time you powered the device with High-Side Gates of 3Volts and 5Volts left floating. The Mosfets are heating up because you probably send 13(?)Volts through the High-Sides into the 3.3V and 5V rail (again) which most likely leave this board as no-fix from here.
            Curiously enough you did not took even one single resistance measurement so far.
            This all is no problem. That the first three or four boards you're trying to fix end up as no-fix is simply normal. However, i don't know who taught you to do how you do, but if you proceed like that with future repairs, you'll kill many boards without realising.
            FairRepair on YouTube
            • Christian0734
              • Nov 2020
              • 92
              • France
              #26
              That's not exactly the sequence of events. Originally, I had a problem with the main power supply, all my voltages were there, I had no short circuit and the computer was running only on battery.
              Without the battery and with the main power supply, it would try to start and stop after 2 seconds, looping 2 or 3 times then nothing. Then inadvertently, I took the probe that I used to power the computer through the battery connector (13v) to measure the 3.2v tension on a fuse. This was a big mistake, I admit, usually I don't connect my multimeter probes to the stabilized power supply, I have other probes for that! I don't know why I made this mistake, but it's too late. I'm not used to injecting current at random, I already knew that the computer was working on the battery, this was demonstrated by a partially charged new battery. Then yes, I briefly powered on with a 3.2v/5v chip desoldered from the board to check with the thermal camera which other component could be heating up, second mistake...
              Currently I'm waiting for your ideas before replacing the 3.2v/5v 1285B chip that was heating up after my unfortunate short circuit. Thank you for your attention and your time.
              Here are the measurements on the inductors.
              • Sephir0th
                • Oct 2020
                • 1289
                One coil with 0.2 Ohms to GND which I assume is the +3.3VALW and another dead short to the left of the CPU which I assume is the +1.05VALW.
                If this is true, and unfortunately this outcome fits pretty good to the history, then there is nothing to do for this poor board anymore.
                • Christian0734
                  • Nov 2020
                  • 92
                  • France
                  #28
                  What does 'VALW' mean? The measurements were taken with one less 1285B chip, I don't know if that changes anything.
                  • mon2
                    • Dec 2019
                    • 14664
                    VALW = always on voltage
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      Dont waste your time and money on this board and go by @Sephir0th's suggestion. He'is pretty experienced man and you should take his criticism in good spirit to upgrade your understanding of laptop motherboard repair.
                      • Christian0734
                        • Nov 2020
                        • 92
                        • France
                        #31
                        yes of course, thank you.
                          HP ENVY Laptop Notebook 16 Specification for Upgrade or Repair
                          This specification for the HP ENVY Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop boardview and Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ENVY Laptop Notebook...
                          09-07-2024, 07:12 AM
                          HP ENVY Laptop Notebook 17 Specification for Upgrade or Repair
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
