Thinkpad Yoga X380 with melody at boot
  • Liken
    • Jul 2023
    • 26
    • Basque Country
    Hi. I bought a faulty thinkpad X380 yoga to see if I can fix it, if possible without changing the motherboard. When it boots the keyboard lights up and a beep melody sounds, black screen and it doesn't go from there.
    According to the Lenovo acoustic identification app, the error is:
    0285: TCG-compliant functionality-related error (might be the TPM initialization failure)
    Is there any possibility to recover it, buying some flash programmer?
  • Liken
    • Jul 2023
    • 26
    • Basque Country
    Re: Thinkpad Yoga X380 with melody at boot
    I'm thinking of buying a CH341A kit. I have been reading several threads in this forum on how to remove passwords from the bios. However, that is not my case.
    The error that it gives I have seen that it is usually related to bios problems, after bad upgrade or similar.
    Do you think that there is any possibility that following the procedure of removing the password the mainboard can be recovered?
    • Sephir0th
      • Oct 2020
      • 1289
      By removing the password from the firmware? No. By flashing a known good Main BIOS firmware: Maybe
      FairRepair on YouTube
      • Liken
        • Jul 2023
        • 26
        • Basque Country
        But from what I've been reading about password wipes, isn't the original board bios specific to that particular board?(*), with specific TPM encryptions?
        Where can I download a generic bios dump for this mainboard?
        DTZS1 LA-F421P
        (*) Remove password protocol. 1.Dump original bios (not another one). 2 patch it. 3. Download patched bios, and instructions to initialize it. 4. Restore original bios.
          • 22187
          DTZS1 LA-F421P
          There`s an X380 password thread in the "Bios requests ONLY!" sub forum here -> https://www.badcaps.net/forum/showth...highlight=X380 .Post your bios backup in that thread if you can`t get the Autopatcher to work , see post #87 .
          • Liken
            • Jul 2023
            • 26
            • Basque Country
            Hi again.
            Finally I have CH431A.
            I have a X380 yoga mainboard. I don't know if it is password locked. It starts, nothing in display and then it sounds a melody.
            I have followed the procedure of patching the bios.
            https://www.badcaps.net/forum/showthread.php?t=87588
            Surprisingly, mainboard works with patched bios, no melody, lenovo logo appears and I have followed the procedure:
            STEP 6: Press space bar 2x when asked
            STEP 7: Turn off machine
            STEP 8: Restore original BIOS
            But, after i restored the original bios, again nothing in display and a melody.
            What can I do? Is the original bios corrupt? If so, why does the patching work? can I download a standard one, where can I get it? And what about the CRC?
            • Liken
              • Jul 2023
              • 26
              • Basque Country
              Finally I downloaded to BIOS a image published in this forum for X380 Yoga.
              It works!!!
              However, something annoying happens. The laptop takes 30 seconds, with a black screen, until it starts to boot and the Lenovo logo appears on screen. It also takes 15 seconds to resume from suspend.
              I have been upgrading and downgrading several bios versions through lenovo repository. I have reset the bios to default, I have tried changing many parameters (quick boot, lan boot,...). I have done all the diagnostic tests on the board and it passes fine.
              but the laptop still takes 30 seconds to see something in screen.
              Any idea about what could be the problem?
              • Liken
                • Jul 2023
                • 26
                • Basque Country
                Maybe the problem (Long time to boot until seeing the Lenovo logo) is related to this that I have discovered.
                ME (Intel Management Engine) firmware is missing in the BIOS
                This is a normal X380 yoga bios for comparison
                I have tried to install ME Firmware from Lenovo in windows but it gives this error:
                Error 8193: Fail to load MEI device driver (PCI access for Windows)
                Above error is often caused by one of below reasons:
                Administrator privilege needed for running the tool
                ME is in an error state causing MEI driver fail
                MEI driver is not installed
                And getting info with MEInfoWin64.exe
                Intel(R) MEInfo Version: 11.8.83.3874
                Copyright(C) 2005 - 2020, Intel Corporation. All rights reserved.
                Error 86: Communication error between application and Intel(R) ME module (FWU client)
                Error 81: Internal error (Could not determine FW features information)
                Could this have anything to do with flashing the BIOS?
                Also I am reporting to this thread: https://www.badcaps.net/forum/showth...ht=X380&page=5
                • Sephir0th
                  • Oct 2020
                  • 1289
                  It needs a "Clean ME" in addition. Nothing more
                  • Liken
                    • Jul 2023
                    • 26
                    • Basque Country
                    I have been reading more on the subject. A couple of questions:
                    1. Can I get a BIOS image of the X380 yoga somewhere with the ME already clean?
                    2. would it be possible to transfer this image to the BIOS from the operating system? That is, without having to open the laptop again and flash it.
                    • Liken
                      • Jul 2023
                      • 26
                      • Basque Country
                      I cannot generate a image with cleaned ME.
                      MEAnalyzer says:
                      Family CSE ME
                      Version 11.8.55.3510
                      I have found these two possible ME firmwares from Intel:
                      11.8.55.3510_COR_LP_C_NPDM_PRD_RGN
                      11.8.55.3510_COR_LP_C_YPDM_PRD_RGN
                      I am using Intel Flash Image Tool version 11.8.86.3877
                      I generate a new image following instructions on
                      https://www.badcaps.net/forum/showpo...41&postcount=3
                      But when I check with MEAnalyze outimage.bin:
                      it Says Type Extracted and Initialized. I was expecting for type Stock.
                      • Liken
                        • Jul 2023
                        • 26
                        • Basque Country
                        Finally, I flashed a BIOS image prepared for me in this thread, and it works well.
                        https://www.badcaps.net/forum/showth...=1#post1271711
                          Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) X Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X380 Yoga boardview and X380 Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 02:28 PM
                          09-06-2024, 01:21 PM
                          09-06-2024, 12:51 PM
                          09-06-2024, 11:50 AM
