Alienware 17 R2 (P43F001) no display
  • Garibean
    • Apr 2022
    • 47
    • France
    i have this Alienware 17 R2 that turns on but gives no display, i connected it with an other screen to see if it gives any display and nothing.
    I don't know what to do to find what is the problem :/
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Alienware 17 R2 (P43F001) no display
    without display does it beep?
    without display with hdmi u have picture?
    withour ram does it beep ?
    • Garibean
      • Apr 2022
      • 47
      • France
      Ok so no beep, nothing BUT the screen turns on, i have a beep when i unplig the battery and replug it.
      So could it be a problem with the vbios or bios ? i'm clueless here...
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        many 17 r2 get dead with shorted cpu mosfet, but to check that u sould disassembly whole mainboard.
        before that did u try reset cmos battery ?
        if without ram no beep can be bad bios, bad pch or bad cpu.
        • Garibean
          • Apr 2022
          • 47
          • France
          My bad, without ram it does 2 beeps and loop !
          And apologies but the laptop show no display, it's an other computer that shows a display ^^'
          Currently i have 2 beeps without ram, i'm reseting the cmos battery now, and i will try to restart it
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            cpu vcore? present ?
            • Garibean
              • Apr 2022
              • 47
              • France
              The vcore is at the end of the big coils next to cpu ? (where the cpu mosfet are)
              I have 1.7v vcore at the end of the coils (between the cpu and the coils)
              are there any schematics for this old alienware ?
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                schematic should be available. check for board code like la-xxxx. if u can try other bios , maybe already posted here.
                • Garibean
                  • Apr 2022
                  • 47
                  • France
                  I tried this method to flash the bios
                  https://fr.alienwarearena.com/ucf/sh...-update-failed
                  But it does not work, the laptop turns on and after a minute or two it reboots, i guess i have to flash it with a chk341a
                  • Garibean
                    • Apr 2022
                    • 47
                    • France
                    Ok little update, i flashed the bios, it looked like it worked with the chk341a.
                    Now i have 7 beeps (CPU failure), so cpu is down i guess but with no short on the mosfets, strange...
                    What else could it be ?
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      try remove cmos battery. then power on. it shoul beep 5 timers. power off then power on again and see if it still beep 7 times.
                      • Garibean
                        • Apr 2022
                        • 47
                        • France
                        So i tried what you said, the laptop turned on 3 times, beeped 5 times then beeped 7 times
                        • Garibean
                          • Apr 2022
                          • 47
                          • France
                          I started to search around the mosfets of the cpu but i don't know how to interpret these values, the mosfets are double mosfets, i don't really know how these works but i got some values :
                          PQ505 & 506
                          G1 to GND : 3k to 5k
                          D1 to GND : 460 ohms
                          S1 to GND : 17 ohms
                          G2 to GND : 30k
                          D2 to GND : 17 ohms
                          S2 to GND : 0 ohm
                          PQ503 & 504
                          G1 to GND : 315 ohms
                          S1 to GND : 17 ohms
                          G2 to GND : 30k
                          D2 to GND : 17 ohms
                          S2 to GND : 0 ohm
                          PQ501 & 502
                          G1 to GND : 480 ohms
                          S1 to GND : 17 ohms
                          G2 to GND : 30k
                          D2 to GND : 17 ohms
                          S2 to GND : 0 ohm
                          SCHEMATICS : https://www.badcaps.net/forum/showpo...33&postcount=1
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            mosfet values are ok. u have all s0 volts except cpu vcore?
                            are u sure bios and ec are ok ?
                            • Garibean
                              • Apr 2022
                              • 47
                              • France
                              I don't know how to verify the state of the bios and EC, i just reflashed the Bios, but i don't have a EC programmer :/
                              • Garibean
                                • Apr 2022
                                • 47
                                • France
                                Any ideas ?
                                • dellxps15
                                  • Feb 2014
                                  • 1588
                                  • italy
                                  ec bios is a 8 pin chip. ec bios and bios must be both ok to make it work.
                                  that kind of problem could also be pch that need to be reballed.
                                  • Techtiger
                                    • Oct 2014
                                    • 1601
                                    • france
                                    If you still get 7 beeps you must test the LPC_AD0 LPC_AD3 LPC_AD2 LPC_AD1 signal with the help of oscilloscope near SIO
