Macbook A1502 820-3476-a no backlight
  • mon2
    • Dec 2019
    • 14258
    Re: Macbook A1502 820-3476-a no backlight
    Yes, that is the output of this load switch. The input voltage is on pin #3. Confirm that pin # 3 voltage remains stable at all times.
    Finally, confirm the voltage on pin # 2 = enable for this load switch.
    What is the voltage reading here to ground ?
    • sdogs
      • Feb 2016
      • 86
      • Italy
      on pin 3 the voltage is stable, on pin 2 without connected display 3.3v with connected display 2.1v, in both cases for a temp of about 3-4 seconds to then return to 0v
      • mon2
        • Dec 2019
        • 14258
        Voltage on pin #3 also goes off after 3-4 seconds?
        Is the display a known good display? Works ok on another board, if you have a spare test board?
        • sdogs
          • Feb 2016
          • 86
          • Italy
          on pin 3 the voltage is stable, the screen should work, nothing else to try nor other logic.
          I replaced the lvds cable on the screen and am waiting for a new LVDS connector for the logic.
          I recovered the LVDS cable from an A1398 screen and I'm sure it worked, maybe it's time to buy a new cable to clear my doubts...
          • mon2
            • Dec 2019
            • 14258
            Measure the voltage to ground of:
            ISNS_LCDBKLT_P
            ISNS_LCDBKLT_N
            EDP_BKLT_EN (U8330)
            LCD_PSR_EN (U8330)
            EDP_PANEL_PWR (U8330)
            • sdogs
              • Feb 2016
              • 86
              • Italy
              #26
              ISNS_LCDBKLT_P 5.1v
              ISNS_LCDBKLT_N 12.5v
              EDP_BKLT_EN (U8330) 0v
              LCD_PSR_EN (U8330) 0v
              EDP_PANEL_PWR (U8330) 0v
              • mon2
                • Dec 2019
                • 14258
                ISNS_LCDBKLT_P 5.1v
                Something is incorrect about these measurements.
                Can you confirm the voltage to ground of PPBUS_G3H?
                • sdogs
                  • Feb 2016
                  • 86
                  • Italy
                  #28
                  yes, I actually made a mistake, here are the correct measurements
                  PPBUS_G3H 12,5v
                  ISNS_LCDBKLT_P 12,5
                  ISNS_LCDBKLT_N 0v - diodo mode 0,80 ohm
                  • sdogs
                    • Feb 2016
                    • 86
                    • Italy
                    #29
                    sorry, i'm messing up, i realized now that i was measuring the wrong place, u5450 is not present on the logic.... here are the measurements
                    PPBUS_G3H 12,5v
                    ISNS_LCDBKLT_P 12,5
                    ISNS_LCDBKLT_N 12,5v
                    • sdogs
                      • Feb 2016
                      • 86
                      • Italy
                      #30
                      what do you think of the measurements? do you think it makes sense to replace the LVDS connector?
                      • mon2
                        • Dec 2019
                        • 14258
                        No.
                        Carefully measure the voltage to ground of the following pins on J8300 with the LCD connected:
                        pin 3 I2C_BKLT_SCL
                        pin 4 I2C_BKLT_SDA
                        pin 6 SMBUS_SMC_0_S0_SCL
                        pin 7 SMBUS_SMC_0_S0_SDA
                        • sdogs
                          • Feb 2016
                          • 86
                          • Italy
                          #32
                          pin 3 I2C_BKLT_SCL 5.1v (for about 2 seconds 4.8v then back to stable 5.1v)
                          pin 4 I2C_BKLT_SDA 5.1v
                          pin 6 SMBUS_SMC_0_S0_SCL 0v (at pin 1 of the r5351 I have 3.3v, in diode mode at pin 2 I give a very low value practically 0 ohm)
                          pin 7 SMBUS_SMC_0_S0_SDA 0.4v
                          • sdogs
                            • Feb 2016
                            • 86
                            • Italy
                            #33
                            without display connected in diode mode to pin 6 SMBUS_SMC_0_S0_SCL I have a normal value, about 0.64 ohm and 3.3v, also the resistance value corresponds to 2 kohm, so the connected display certainly creates some problems
                            • sdogs
                              • Feb 2016
                              • 86
                              • Italy
                              #34
                              No.
                              pin 3 I2C_BKLT_SCL
                              pin 4 I2C_BKLT_SDA
                              forgive me if I bother you even on the weekend.. what do you think? it seems that when it detects the display it all goes down the drain
                              unfortunately I don't have other displays to try, only a 2015 but it's not good for this logic board
                              • mon2
                                • Dec 2019
                                • 14258
                                I am concerned if the LCD display is compatible with your logic board.
                                See this thread here:
                                https://www.badcaps.net/forum/showthread.php?p=984520
                                To confirm, the LCD display being tested is not the original supplied with this laptop?
                                • sdogs
                                  • Feb 2016
                                  • 86
                                  • Italy
                                  #36
                                  Tomorrow I'll ask the owner but I'm sure it's his display, I'll update you as soon as I have the exact information
                                  thanks for your time ;-)
                                  • sdogs
                                    • Feb 2016
                                    • 86
                                    • Italy
                                    #37
                                    he assured me that it's his display .... at this point I'm still and I don't know whether to give up .... what do you think?
                                    • rex98
                                      • Feb 2023
                                      • 1280
                                      • Mandaue CEBU, Philippines
                                      #38
                                      I solved mine backlight problem 0V in L3095 and L7710. i just guessed😂 and replaced the U7700 and Q7701 it works. try it
                                      exact same model of yours.
