Macbook 820-01814 PP3V3_G3H short
  • reformatt
    • Feb 2020
    • 1404
    So bought a dead A1990 board off eBay (820-01814). Don't know the history other than it's iCloud locked and not working. So hopes weren't high.
    Board is relatively clean, appears to be some evidence of some type of cleaning in some areas but no rework evident. Anyway, in summary PPBUS_G3H has a 2 ohm impedance to deck, and this was traced to the same on PP3V3_G3H_RTC. U6960 (TPS62180) had shorted so its had the full 12V dumped on the 3.3V line. PPBUS short was gone after U6960 removed and isolated the low resistance to after R6934/R6935 (no output filter cap shorted unfortunately). Removed U3200 (CD3215) and resistance went up to 9 ohms. Was hoping that one may have failed and saved the others but all 4 CD3215's were done and dusted.
    So now have 60 ohms on the PP3V3_G3H_RTC rail, which is still too low and likely other damaged components on this rail. Some are minor but we do have the SSD and PMU power regulators being fed by this. No data sheets so don't know if 12V input is excessive or not.
    So in a nutshell, just wondering if anyone else who have had a shorted 3V3 RTC regulator on these T2 MAC's whether this is a recoverable situation or not? I have another T2 board from a 2018 MAC that I got dead, where it seems the last repair fixed the 3.3V regulator and stopped after that. 13 ohms to ground on this rail so it doesn't seem like a one off.
  • MacMazel
    • Aug 2023
    • 3
    • Czech republic
    Re: Macbook 820-01814 PP3V3_G3H short
    Hello I had the same problem , today I solved it was W710 in short
    • MacMazel
      • Aug 2023
      • 3
      • Czech republic
      here is the position of bad component
      • barry101
        • Aug 2019
        • 61
        Thanks for the fast reply! Unfortunately, that appears to be a different model board and I can't find W710 on the schematic for my board to try to locate a similar part.
        Thanks though for your help, appreciate it.
        • barry101
          • Aug 2019
          • 61
          My apology, I just noticed this is not my thread (had similar title) but I do have the same board as the author.
          Sorry
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • sdogs
            macbook pro M1 a2338 no video on internal display PP3V3_S2 short
            by sdogs
            Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
            First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
            I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
            06-27-2025, 01:58 PM
          • sdogs
            by sdogs
            06-27-2025, 11:26 AM
          • Arshad alam4659
            MACBOOK PRO A2141 SSD SHORT
            by Arshad alam4659
            I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
            PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
            Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091
            10-01-2024, 08:26 AM
          • envym
            MacBook Pro 2018 with Activation Lock
            by envym
            Hi everyone!
            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
            06-27-2025, 08:54 AM
