MacBook Pro 15" A1707 820-00281 repair
  • jma46
    • May 2020
    • 24
    Hi I am currently trying to repair a A1707 0820 00281 logic board, PPBUS_G3H gives a negative voltage reading of around -.5v but checking the rail for shorts, seems fine. In the past in this same scenario if I had a negative voltage I would expect to find a short. This is a liquid damaged board and is only drawing .01-2 amps and 5v. Could the short be in between the board layers?
    Thanks JMA
  • mon2
    • 14677
    Re: MacBook Pro 15" A1707 820-00281 repair
    Remove the fuse(s) on the ppbus_g3h rail.
    Then test again to see the voltage is the correct range.
    What is the voltage of the USB-C power into the logic board?
    Is it 20v or is it lower? Normal is 20v.
    • jma46
      • May 2020
      • 24
      Hi Mon2 removed the fuse pubs_g3h USB-s is 5.03v darling .01-2 amps
      • mon2
        • 14677
        5 volts means the logic board is using the default output voltage from the power adapter. After some handshakes using the CCx pins on the ACE controllers, the board should kick into 20v mode.
        See the article on the net by @Piernov and gang on how 20v is selected for the gory details but start with carefully measuring the LDO regulator rails of each ACE controller. Summary is that there is a fault in one or more of the USB-C ace controller. Each one must be functional to dial up to 20v.
        • mon2
          • 14677
          https://logi.wiki/index.php/CD3215_Bootup_Sequence
          • jma46
            • May 2020
            • 24
            Im fairly new to all this but picking up odd things as I go, this board in particular, I seem to be getting negative voltage readings off some of the ground points, does that mean I am wasting my time with this board? Thanks for your reply and the link, I will look and try to understand
            • mon2
              • 14677
              As far as I know, there are no negative rails onboard. If the meter is working correctly and calibrated to the manufacturer's specs, you should not see negative voltages. Are the values small or large for the measurements of the negative scale? Perhaps a no care. You can check the same test points with another meter to be sure.
              For the main power rail -> your external power adapter is the feed for the power path -> starts @ 5 volts till the CD321x controllers (CD3215 on your board) handshake and then select 20V power delivery contract. Either way, the 5v or 20v are fed into the ISL buck / boost regulator. If 5v is the INPUT; then the regulator will BOOST to ~12-13v. If the input is 20V as the INPUT; then the same regulator will BUCK the voltage to the lower range (same as above). No negative voltages here.
              At this time, since you have only 5 volts being selected (actually is the default on voltage from the adapter) -> need to confirm the CD3215 devices are working. One bad CD3215 can halt the 20V selection process. The above linked article outlines the steps required to reach the 20v power delivery contract. The first step is to confirm that each LDO pin on each CD3215 is able to supply the proper voltage.
              The LDO is a linear regulator that will take in the 5 volts and lower it to the voltage on the pin as shown in the schematic. After this confirmation, move the power head to another CD3215, etc. and test again.
              • jma46
                • May 2020
                • 24
                Hi Mon2 I have been flipping between a faulty A 1708 and the A1707 both with similar problems, the A1708 has PPBUS_G3H and P3V3_G3H and no shorts I could find and was not booting. After reballing several CD3125's and no success I went back to the A1707 looking through the links you supplied and the LDO.s required etc. After removing and reballing some more CD3125's from a diner board the voltage shot up from 5-13-20v! and realised it was booting! I have put back in the case and also got an image although it may be flexgate, I had made some good progress which I will look at further when I get a minute. There are some components missing from the board which I do not know what it is, can anyone tell me what the R3540 is on the schematic, the only info it shows is - 0.002 1% 1/2W MF 0306. A google search does not help identify what it is? thanks for the help Mon2 I really appreciate the help
                • mon2
                  • 14677
                  That is really good news. The resistor is a 2 milli-ohm current sense resistor and the smd package 0306 size.
                  Best to search on 0306 smd size and then check if the value is available. Will do the same after my daily dosage of Netflix - Money Heist. My latest addiction.
                  • jma46
                    • May 2020
                    • 24
                    Still no luck with defining the part, I have Flexbv but limited info on the schematic I have
                    • mon2
                      • 14677
                      https://www.digikey.ca/en/products/d...F-T50/16735421
                      • jma46
                        • May 2020
                        • 24
                        Thanks Mon2, that's brilliant Ill get some ordered, I have tried all sorts of searches but don't fully understand what the part is, but glad you do!
                        • CG_Dionysos
                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                          by CG_Dionysos
                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                          • Model: A1707
                          • 15-inch, Mid 2017
                          • 3.1 GHz Core i7
                          • 16 GB RAM
                          • Radeon Pro 560
                          • 1 TB SSD
                          • Board number: 820-00928-A
                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                          Thanks in advance!
                          Greetings from Germany...
                          09-16-2025, 06:43 AM
                        • leonemax81
                          Macbook a1707 820-00281 Battery no Power
                          by leonemax81
                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                          08-23-2024, 09:24 AM
                        • sofles
                          Macbook a1707 2017 model 820-00928 GPU issue
                          by sofles
                          Hello there
                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                          11-21-2024, 05:25 AM
                        • jesi
                          MacBook Pro 820-00281-A A1707 macbook
                          by jesi
                          hi all techs
                          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                          update:
                          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                          08-23-2025, 02:35 PM
                        • tommy97
                          Apple MacBook A1707 No Audio/Sound
                          by tommy97
                          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                          I've also replaced U6300, but the problem persists.
                          Here are the current voltage readings:
                          • PPV18_S0: 1.8V
                          • R6402: 1V
                          • R6405: 1V
                          • R6403: 1V
                          • AUD_SPKRAMP_RESET_L: 1.3V
                          • PPBUS: 12.6V
                          03-10-2025, 11:22 AM
