Dell Latitude E7440, LA-9591P, not booting suspecting VCC_CORE
  • ayavilevich
    • Jun 2023
    • 6
    • Israel
    A E7440 laptop stopped working. Not booting. Nothing is shown on the screen. Power and charge LEDs will light (on and off in sequence) when plugged in. Fan not spinning except for when pressing the power button to turn off the device.
    The board is LA-9591P. I have schematics and board view.
    The processor is i7-4600U. Getting warm/hot when plugged in.
    I took the board out and tested some power rails. All seems ok except that I don't know what should be the right core voltage. VCC_CORE measures at 1.74V. Is that right?
    If not right, what could be wrong and is there any chance the CPU is still ok?
    If that is right, what should I check next?
    For the record I tested the following rails:
    +5V_ALW - ok 5V
    +3.3V_ALW - ok 3.3V
    +3.3V_ALW_PCH - ok 3.3V
    +3.3V_RTC_LDO - ok 3.3V
    +3.3V_SUS - ok 3.3V
    +1.35V_MEM - ok 1.34V
    +5V_RUN - ok 5V
    +3.3V_RUN - ok 3.3V
    +0.675V_DDR_VTT - ok 0.681V
    +1.05V_RUN - ok 1.05V
    +VCC_CORE - ? 1.74
    +3.3V_M - ok 3.3V
    +1.05V_M - ok 1.062V
    Thanks in advance,
    Arik.
  • Sephir0th
    • Oct 2020
    • 1283
    Re: Dell Latitude E7440, LA-9591P, not booting suspecting VCC_CORE
    Test with Known good DDR3L RAM, to start with. From there you should rule out a corrupted BIOS first.
    FairRepair on YouTube
    • ayavilevich
      • Jun 2023
      • 6
      • Israel
      I tried two different DIMMs. Both same behavior. I don't have something else right now to try.
      If I install no RAM then the LEDs light up in a special "no ram" LED code.
      How can I rule out a corrupted BIOS?
      This laptop doesn't have an official BIOS recovery process.
      Any suggestions or guides on dumping or flashing BIOS for this model?
      • TuanTongbadcaps
        • Mar 2023
        • 64
        • VietNam
        You should try flashing the bios chip with another good rendering from the forum to rule it out.
        • ayavilevich
          • Jun 2023
          • 6
          • Israel
          Does this necessary mean removing the flash chips from the board or can they be programmed in circuit?
          Any guides for that?
          • ayavilevich
            • Jun 2023
            • 6
            • Israel
            What about VCC_CORE? Is 1.74V correct for this laptop?
            • Sephir0th
              • Oct 2020
              • 1283
              Intel 4th Gen CPUs uses Fully Integrated Voltage Regulator ( FIVR ) and 1.8V there is absolutely fine. Otherwise I wouldn't had suggested to continue with BIOS.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Take Sephir0th's advice and flash the bios first. You can use the files (flash both) in this post (tested by me, I've also cleaned the ME Firmware - the dump is for sure 100% OK):
                https://www.badcaps.net/forum/showpo...9&postcount=47
                Become a Badcaps supporter
                Thanks to all supporters.​
                • ayavilevich
                  • Jun 2023
                  • 6
                  • Israel
                  Thank you Sephir0th, TuanTongbadcaps and Vesko356!
                  Got a CH341A programmer and a 8-SOIC clip. Flashed good firmware from the forum on both chips. Laptop works and will be put to good use.
                  A win for the right to repair!
                    DELL Latitude E7440 Ultrabook 7000 Specification for Upgrade or Repair
                    This specification for the DELL Latitude E7440 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7440 boardview and E7440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                    09-06-2024, 04:40 PM
                    09-06-2024, 04:10 PM
                  • Aeisens
                    Samsung UE50RU7170 not booting /no picture
                    by Aeisens
                    Dear all,
                    My issue is the following:
                    Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
                    I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
                    Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
                    Question 1: Where should I start to...
                    06-24-2025, 03:07 PM
                  • Daniel Kubica
                    Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
                    by Daniel Kubica
                    I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
                    I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
                    06-14-2025, 09:24 AM
